Losing Coolant
Old Oct 4, 2004 | 11:46 AM
Ed Blown Vert's Avatar
Default Losing Coolant
Well, this morning I noticed white smoke out of the exhaust when I was warming up the car. Once the car is warmed up, it was fine. And lately I have been losing coolant.
My guess is a leaky head gasket. But what else could it be?
*I wish my heads would get here*
Old Oct 4, 2004 | 12:07 PM
ToddAlmighty's Avatar
my friend has a T/A that he knows nothing about, nor does he take care of. he had that problem for about 1-2 weeks before he did anything about it. it just got worse and worse, until he washed #7 out. couldnt get the car to start. it was a leaking head gasket.
Old Oct 4, 2004 | 01:35 PM
technical's Avatar
Head gaskets, that's about all it can be. You're sucking coolant into the cylinder. Fix it now, or pay up later.
Old Oct 4, 2004 | 01:40 PM
Good, simple fix. But what could be damaged?
I am trying to hold out till my heads come in. But looks like I cannot wait anymore.
Old Oct 4, 2004 | 01:47 PM
technical's Avatar
If you mean what's the worst case scenario...bottom end. You could easily wipe out a piston. Or worse bearing damage.
Old Oct 4, 2004 | 02:43 PM
LOnSLO's Avatar
You could always load it up with Alumaseal and see if that helps till your heads arrive.
Old Oct 4, 2004 | 04:18 PM
You must mean from excess coolant in the cylinder. Makes sense.
Old Oct 4, 2004 | 04:19 PM
I thought that stuff only works with radiators?
Old Oct 4, 2004 | 04:31 PM
technical's Avatar
You probably don't have cylinder or head damage, but instead have a gasket that "blew out" and it bleeding the coolant into the cylinder. Additives will not fix this.
edit: Even if you had a cracked head or case, they need to be replaced not sealed with an additive.
Old Oct 4, 2004 | 05:19 PM
I can deal with a blown gasket. Thanks.
Old Oct 4, 2004 | 09:52 PM
Ragtop 99's Avatar
Pull your #7 plug and see if it looks washed. When I had a powerdyne, that's where I blew.
Old Oct 4, 2004 | 10:25 PM
Thank, I'll pull them this weekend.
Old Oct 4, 2004 | 10:28 PM
SSilver's Avatar
heyyyyyy Ed............
thats what you get when you put a blower on 11:1 compression...
