Currently building a 418ci and need help
Old Oct 7, 2004 | 11:22 PM
Ben R's Avatar
Originally Posted by SpeedDemon
Gotta go with KingCrapBox here. Nitrous is really not that compression sensitive. It is nothing like FI.
For nitrous, you definitly want to bring the top ring down as far as you can. The shorter rod will allow you to do this. If you can, I would go with the shorter rod.
Good luck,
A prime example for this would be to look at Sam Vincent's Mustang. He's one of the only people running SSO with a nitrous setup. What is his compression? High. Any fast nitrous car has lots of compression.
Old Oct 7, 2004 | 11:57 PM
418ci's Avatar
I agree, look at IHRA Pro Mods, I bet the guys that run nitrous have lots of compression. KingCrapBox do you like nitrous as a power adder?
Old Oct 8, 2004 | 08:12 AM
SLED28's Avatar
You are going to have to find out what the Compression Height is on those BME pistons.
Old Oct 8, 2004 | 09:20 AM
418ci's Avatar
Piston compression height is 01.075 with a 6.125 rod. Not sure if I'm going to even use the BME's.
Old Oct 8, 2004 | 10:25 AM
SLED28's Avatar
Hmm, awfull comp height. You could possibly use them with a 6.100 rod and 4.100 stroke and it'll be 10 thou out of the hole. I am not sure if the piston will clear the crank weights without any 'major' massaging. I happen to have a 4.100 stroke crank right now I'm not using...
Old Oct 8, 2004 | 11:00 AM
418ci's Avatar
how much you want for it, what kind?
Old Oct 8, 2004 | 11:07 AM
SLED28's Avatar
Its an Eagle 4340 crank.
Old Oct 8, 2004 | 06:59 PM
Ben R's Avatar
The torque nitrous provides is fun but there's nothing like a big turbo making big boost.
Old Oct 8, 2004 | 08:15 PM
418ci's Avatar
Turbo and nitrous
