How to change lifters?
When I do my cam and heads swap this spring, I planned on changing the lifters since I have 67k miles on my car. Does anyone know of a walkthrough or have the steps necessary to do this? Thanks in advance.
<strong> The best source for this sort of information is your car's service manual. Duplicating or even summarizing that information here would require considerable effort. Many questions such as yours go unanswered for these reasons. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">No offense, but you could give that response to probably over half of the questions asked on a board like this. The whole point of having access to an internet form like this one, or the various other car related forums is to share the knowledge and experience of thousands of other people who have the same interests as you.
Simply referring them to a service manual really defeats the purpose of an internet forum since not everyone has access to a service manual.
And to Onyx, thanks for the info. I didn't think it would be hard, I just wanted to make sure since NONE of the head swap walkthroughs I've seen on the 'net even mention it.
-Gary
Although I may not post here much, I post over on one of the other boards quite a bit. I do not consider myself to be an all knowing expert on here, but I do know enough to do a cam swap.
I appreciate Gary's concern for not wanting me to get in over my head with a lifter change, but as everyone here has said, it is super simple once the heads are off, and I can be the judge if theres something I can or cannot do myself. That is all the information I wanted.
PSJ, I did read the head swap info on www.ls1howto.com and the one over at www.ls1info.com, and neither of them mention how to get the lifters out, that is why I asked this question.
I try my best to help other people out on these boards when someone asks a question that I have experience with, and that is all I wanted out of here. In response to me being labelled as fussy, I apologize if I came off that way, but I did wait 2 whole days for a response and didnt get one. Thats why I came over to this forum to ask my question.
I dont want anyone to think Im trying to be a troublemaker here, but I try to follow the rules as best as possible on these boards, and I just get irritated when a simple question like I asked gets turned into a multi-responsed Battle Royale where are calling me names and questioning my ability to perform such an easy task.
Lastly, thank you to those who took the time to answer my question.
<strong> PSJ, I did read the head swap info on www.ls1howto.com and the one over at www.ls1info.com, and neither of them mention how to get the lifters out, that is why I asked this question.
</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Straight from LS1howto.com's head/cam swap page:
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Pull up both head gaskets and discard them. Underneath the gaskets, you can see 2 10mm bolts holding each lifter retainer cup (the brown plastic things holding 4 lifters each). Unbolt the lifter retainers making sure to NOT DROP THE BOLT, and then pull them up and out. You should get a few lifters still stuck in each retainer, grab the ones that didn't come out and put them in the lifter retainer in their proper place. Again, keep the lifters in order just for good practice. Repeat for the other side of the engine. Place a rag in each lifter section (4 sections on each side of the block) to keep debris out of the engine.
-Gary
1) Heads have to come off. Lifter swap should be treated like a head swap.
2) take out the bolt that holds the lifter keeper thingie in, and then pull it up... Voila lifters come out.
I am being fussy for a good reason. You obviously have a lot of experience working on LS1 engines. I think it is important to not lead those with less experience into making expensive mistakes. At the very least you need access to torque specifications.
-Gary
Try www.ls1howto.com for head swap info.
GaryZ's answer is ummmm not that great if we all took that advice we would not need LS1Tech. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
I want all of you to stand in a row so I can run you all over at the same time.
IMO I would not change lifter unless I was going to pull the heads for other reasons...
