Head W/ Light Cam
Old Oct 9, 2004 | 03:52 PM
jz06man's Avatar
Default Head W/ Light Cam
Has anyone done a Stage 2 head with a light cam-
(Patriot(upgraded valve)
DUR @ .004" 272*/280*
DUR @ .050" 210*/218*
LIFT .551 / .551
OVERLAP 52*
LSA 112*
Does anyone have any ideas how much might i pick-up with this cam. I know this is a light cam, almost the Z06 cam, but I'm told it should make a bit more hp, but alot of Torque down low & mid RPM's. If true, this is what I'm looking for with a stock idle
Old Oct 9, 2004 | 04:43 PM
z98's Avatar
z98
Colonel makes 430 RWHP through an auto with stage 2 heads and a stealth II cam.
Your cam will NOT have a stock idle.
Not even close.
For a stock idle, you need to try a cam in the 116+ LSA range (Z06 and SII come to mind).
Old Oct 9, 2004 | 04:44 PM
someday's Avatar
its not gonna have a stock idle on a 112lsa... being so small, and on a 112, its gonna peak kinda low, maybe 5500... but it will make a killer midrange... if u want more of a stock idle, i'd try a TR220/114, or MTI's SS1
Old Oct 9, 2004 | 06:31 PM
jz06man's Avatar
It Will have a near stock idle.... LSA is not the only thing that determines stock idle quality. This cam has only a overlap of 52 or 48, i forget...
but thanks for the input....
Old Oct 9, 2004 | 08:33 PM
MNR-0's Avatar
LIFT .551 / .551
OVERLAP 52*
LSA 112*
I havent done any heads/cam yet, but I looked long and hard at that cam and its hard to beat for what it is designed to do. I will be putting in a custom self-designed cam in the near future, but that cam is as very good choice for streetability. You might also look at a 212/212 comp XE high lift. Another very good torquer with an even better idle.
Old Oct 10, 2004 | 11:46 AM
z98's Avatar
z98
I heard a lunati cam on a 114 about that same duration.
It didn't sound anywhere near stock.
You will be very disappointed if you think that will sound stock.
Whatever.
I'm done.
Old Oct 10, 2004 | 04:08 PM
jz06man's Avatar
Well stock to one way not be stock to all. this cam is near a Z06 cam which i currently have. this cam will be a bit more aggressive, but not rock or have a choppy idle....
Old Oct 10, 2004 | 04:59 PM
ForceFed HP's Avatar
Suspended Sponsor Account
with a set of our stage 1 heads and a 212/218 .560ish 115LSA cam we had a guy hit 377rwhp and 400rwtq stock exhaust manifolds and LS1 intake. car was an M6
Old Oct 10, 2004 | 08:44 PM
jz06man's Avatar
Forcefed hp,
Thanks for the update. Any Modifited Z's with this type of cam- I am currently just above 390RWHp and 380RWTQ... Or any Z's with stock cam with Stage 1 or 2 heads..
Thanks'
