Revving to 14,000 rpms?
I figured something up with my engine analyzer. If an LS1 was destroked to 300ci, it would still be pulling almost TWELVE THOUSAND G-FORCES at 14K RPM! Just for comparison, a stock displacement LS1 pulls only (and I say only) about 4300 Gs @ 8500RPM, and guys really push it getting there.
What material do you plan on asking to experience forces 14000 times its own weight?
Now.... I think the skeptics have adequately illustrated the point that this is an impossibility for an individual without some high engineering degree and advanced understanding of metalurgy.
Wondering where you came up with that last conclusion.
You dont, so, you don't
[edit]
Damn it Z98, you beat me to it.
if 14000 rpms was the efficient way to make power....then why wouldnt people with unlimited funds do so?...like nhra pro stock.
it just seems like 10k is the hot set up...on many different forms of max effort drag race engines. "maybe" theres a reason why...maybe it starts to get less efficient after that or something...otherwise it would be happening...theres plenty of people that have the coin to be trying this in the racing world.
You'll never be able to get an ls1 the way we know it to that high an rpm:
-loads on the rotating assembly increase exponentially w/ rpm. in other words, the forces at 8k rpm are not double that at 4k rpm, but thye are actually 4X larger....you get the idea.
-F1 cars can rev that high because (among other things) they have much lighter valvetrains and bottom ends. Lighter parts allow less momentum and lower forces on the assembly. Also, as mentioned before, the stroke is much less, resulting in lower piston speeds (pistons cover less distance in the same amount of time as our ls1s for a given RPM. This lower piston speed reduces the momentum/forces on the piston, allowing it to hold together when it changes direction.
So due to the limits of our materials you cannot build an ls1 to rev that high. There is no material that you could use to make our engines hold up at 14000 rpm.
So you CAN make an engine rev that high-it just wont be an ls1 due to it's inherent design: large rotating mass, heavy valvetrain, and bore/stroke.
Small engines can rev incredibly high due to their low mass - I've used a model airplane engine that revs to 20,000. it only cost 200 bucks. It's all a matter of physics, and the the limitations of the materials avaliable.
