Cleaning the block on a head swap!
You mean this is your first H/C install, you go through all the pain you have, without experince, then you back off at the pistons??
They are not eggshells you know.
I thought you weren't supposed to use a tap?
BTW stock gaskets are graphite coated.
I ground down one sid eof a bolt and did that, wasnt working well...the same as a normal bolt...i'll try grinding both sides and see what happens...
It's really not a good idea to start mucking with the pistons. You'll never get all of the carbon off and end up making a pattern that'll most likely cause you headaches...IMO.
I took a wire brush to the bolt before i put it in the block... but it still seems to not be working well..maybe i'm just over worried about messing something up...ive had the bolt in and out of one hole now about 40 times and its still comming out with atleast some gunk on it each time...not much at all, but a little... i can see it when i wipe it on a clean cloth.
should i be torquing the bolt down too a little with a wrench?
so now im gonan have to deal with a blown motor or head gasket cause of metal shavings.
do i need to heat cycle or anything for the new heads? break in im assuming is probably areond 500 miles, but do I need to do anythong on start up initially? What's the process?
