TheAftermath. For ur LS1 Internal Viewing Pleasure
Number 7 Cylinder (blocks cracked all the way through)
Number 7 Cylinder
You Can See The Rod Through The Cylinder Wall Sticking Out
thats also where the Oil Filter went
.jpg)
Number 8 Cy,inder
The Other Side (didn't get any better
Heres the HEADS
Heads Destroyed, you can see the bent L shaped stem and the Valve guide stretched, cracked etc, anyone want to buy a head
Nice L shaped Valve Stem for ya, have yet to find the Valve Head
Another
You can also see the piston ring stuck in the head still
Seriously, I'm sorry that happened to you. It's so much easier being the guy looking at the pictures than the person who needs to figure out their next step. Good luck, man!!
Definatly some of the worst ls1 destruction Ive seen...Sorry that happened to ya, but that just means you have the chance to start over and you can go with any setup granted you got the dinero. Unless you can cut the ls1 in half and make it an I4...could be interesting
Good luck with your next step
427 time
