6.0 HEADS WORTH IT?
Thanks for any help.
<small>[ April 07, 2003, 05:50 PM: Message edited by: Linear Velocity ]</small>
Numbers from Jason99ta
Stock LS1 5.7 vs Stock 6.0 head numbers
Lift LS1 Intake 6.0 Intake
</font>
- <font size="2" face="Verdana, Helvetica, sans-serif">.100 67.6 66.3</font></li>
- <font size="2" face="Verdana, Helvetica, sans-serif">.200 121.9 142.5</font></li>
- <font size="2" face="Verdana, Helvetica, sans-serif">.300 177.5 195.9</font></li>
- <font size="2" face="Verdana, Helvetica, sans-serif">.400 214.5 228.0</font></li>
- <font size="2" face="Verdana, Helvetica, sans-serif">.500 219.3 235.7</font></li>
- <font size="2" face="Verdana, Helvetica, sans-serif">.600 227.1 240.4</font></li>
- <font size="2" face="Verdana, Helvetica, sans-serif">.700 231.9 245.5</font></li>
Lift LS1 Exhaust 6.0 Exhaust
</font>
- <font size="2" face="Verdana, Helvetica, sans-serif">.100 51.9 59.1</font></li>
- <font size="2" face="Verdana, Helvetica, sans-serif">.200 96.6 104.2</font></li>
- <font size="2" face="Verdana, Helvetica, sans-serif">.300 132.5 136.5</font></li>
- <font size="2" face="Verdana, Helvetica, sans-serif">.400 155.7 155.2</font></li>
- <font size="2" face="Verdana, Helvetica, sans-serif">.500 170.0 167.3</font></li>
- <font size="2" face="Verdana, Helvetica, sans-serif">.600 179.8 176.8</font></li>
- <font size="2" face="Verdana, Helvetica, sans-serif">.700 185.2 181.2</font></li>
Your going to gain cylinder head CCs. But don't get to excited about that... The stock 6.0 heads have bigger chambers than your 5.7 heads. And those bigger chambers will lower your compression ratio. Thats good if your running lots of boost. However, in your case, you just [lost] HP and torque.
Ron,
<small>[ April 11, 2003, 10:43 PM: Message edited by: Tin Indian ]</small>
I milled my 6.0 0.030 and the chambers cc'd to 63.5 cc. With mild porting and Ferrea 2.02/1.55 valves I picked up 20hp.
Without out porting and milling the 6.0, it's not worth the swap. Buy a set of Stage I's from one of the spronsor if you are looking for a budget increase. Porting them yourself is not worth your time either, trust me.
