PLEASE HELP! I hear a noise? what is it
Old Oct 21, 2004 | 03:38 PM
stangeater01's Avatar
Arrow PLEASE HELP! I hear a noise? what is it
ok i went to the track on sat. ran the car 4 times and on the forth time i blew my cerp. belt off i didnt realize it till i was going to pull back in line and i realized my power steering was out. I pulled the car on the trailor and then my radiator over flowed thats when i realized my car over heated the temp gauge on the cluster read 250 so i wet home put a new belt and added fluid. now the motor is making a knocking noise but spraticly not constantly its on the passenger side. It will do it every 20 sec or so then maybe 40 sec's later, its just not consistant. I pulled my plugs last night and they looked fine aclually pretty damn nice. I then pulled the rockers and the push rods (on pass side) and they are fine. I am doing a compression test this evening. What is next in line to check??? what could this be maybe a valve spring?? What do you all think. Any advice would be greatly appreciated
O i have a 6.0 iron block with lunati pro billet rods, crank dimond nitrous pistons and ls1 stage 2 heads
Thanks Richard
Old Oct 21, 2004 | 04:10 PM
goober35's Avatar
Could be a spring or it could be a loose TC bolt witch can happen time to time.
Old Oct 21, 2004 | 04:15 PM
TC what is this, any other possibilities??
Old Oct 21, 2004 | 04:17 PM
is there a tool to check the springs??? if so what is it called and where can i get one??
Thanks Richard
Old Oct 21, 2004 | 05:35 PM
goober35's Avatar
spring u can check by hand and by looking at them. TC=Torque Converter.
Old Oct 21, 2004 | 07:17 PM
ok i did a compression test and 3 cylinders read 210 and the 3rd was 180 what is next what should i check now??
Old Oct 22, 2004 | 03:14 PM
TD's z's Avatar
to be on the safe side i would check my oil for coolant
Old Oct 22, 2004 | 03:36 PM
what if there is coolant?? the knock is comming from the top not the bottom sounds like valve train noise
Old Oct 22, 2004 | 03:41 PM
chupr0kabra's Avatar
If there's oil in the coolant, that's usually a head gasket.
-Mike
Old Oct 22, 2004 | 03:49 PM
1970judge's Avatar
i ran my car at the track and heard a knocking my noise came out to be a slightly loosened rocker arm from turnign hard rpm's...fixed by simply tightening it..unless you bent the pushrod..
?? o coolant in the oil i guess if it were a ring then my car would smoke right???
Old Oct 23, 2004 | 10:22 AM
1970judge's Avatar
if it were a pistn ring you mean?...if tahts what you man then you car wouldnt even run the compression would drop and you car wont start..i doubt its a ring..sounds liek valvetrain to me.
Old Oct 24, 2004 | 02:12 PM
well thats good news i can deal with pulling a head or both but pulling the motor would have pissed me off
Old Oct 24, 2004 | 02:14 PM
it sounds like the noise stopped now BUT i sprayed water on my headder tubes 3 would not even make contact would sizzle off so quick and the other will just burn off so one cylinder is colder than the others much colder i just put brand new plugs today
Old Oct 24, 2004 | 02:20 PM
cyphur's Avatar
hmm....usually if you blow a head gasket the car smokes bluish white. i know my 280z looked like a damn smokestack when it went, and it had a minor headgasket failure.
Old Oct 24, 2004 | 07:33 PM
yea i know what you mean i think it has something to do with the valves?????
Old Oct 24, 2004 | 09:14 PM
blacktransam's Avatar
really sparatic exhaust leak??
Could really be anything.. collapsed lifter
Old Oct 25, 2004 | 08:51 AM
what would cause the header tube on that cylinder to be colder than the others??
