Ed Curtis (EDC) cam specs
Old Dec 13, 2004 | 12:34 AM
  #81
Beast96Z's Avatar
Originally Posted by P Mack
Jrp, I'm guessing you took the engine out from the bottom. Are you gonna do a write up on that? Cause that would be awesome. Looking forward to hearing your custom cam results too.
I did a small right up about it a few weeks ago. Do a search for my name and the post should come up.
Old Dec 13, 2004 | 01:00 AM
  #82
jrp's Avatar
jrp
SN95 Director
i pulled the engine out as a shortblock from the top, tranny was already out. i pulled the k-member and a-arm from the bottom, obviously. k-member, engine, and tranny will all go in from the bottom when i put it back together. didnt plan on doing a write up as theres already plenty of decent walkthroughs out there. i must say though that the car was alot higher then i thought it'd be , the head lights were even with my head and im 5' 6".
Old Dec 13, 2004 | 01:25 AM
  #83
NLang's Avatar
Damn, too bad you're not into drag racing. Short and skinny: A narrow midget kart seat-extra cage room, and weighing just over 100lbs is like a measly 10hp loss to the car. Want to run down the strip a few times for me? Hell, that's another 100lbs off my car
Old Dec 13, 2004 | 01:29 AM
  #84
jrp's Avatar
jrp
SN95 Director
Originally Posted by NoseUp
Damn, too bad you're not into drag racing. Short and skinny: A narrow midget kart seat-extra cage room, and weighing just over 100lbs is like a measly 10hp loss to the car. Want to run down the strip a few times for me? Hell, that'd be like another 100lbs off my car
who says weight reduction is only for the strip . nothing like more power and less weight to add to the fun of lapping a road course .
Old Dec 13, 2004 | 01:39 AM
  #85
NLang's Avatar
Motivation to drop the weights this winter and get going on some cardio
Old Dec 13, 2004 | 02:41 AM
  #86
family sedan's Avatar
Let us know the dyno results of this uber el8 cam. Sure, it's a dyno but share the honesty when you can.
Old Dec 19, 2004 | 03:28 PM
  #87
hink9's Avatar
Originally Posted by Beast96Z
Who said it was a "reverse" split????? Remember .050" number don't mean jack........
could someone enlighten me, or point me in the right direction on how a cam could read reverse split at .050 but not anywhere else. im confused
Old Dec 19, 2004 | 03:41 PM
  #88
pkincy's Avatar
Try "Chevy LS1/LS6 V-8s" by Will Handzel, whose day job is with GM Performance Parts. Just out. He has pages and pages of instructions and pix of the R and R from the bottom. Avail from Amazon as a package with the other LS1 book that has been out for a bit.
Perry
Old Dec 19, 2004 | 06:01 PM
  #89
Cstraub's Avatar
Ramp rates/lifter velocities.
Chris
Old Dec 19, 2004 | 06:04 PM
  #90
hink9's Avatar
Chris
i think i understand thanks chris
Old Jan 24, 2005 | 01:40 PM
  #91
CamTom12's Avatar
Hey JRP, any more progress on the motor?
Old Jan 24, 2005 | 02:37 PM
  #92
J-Rod's Avatar
6600 rpm clutch dump of death Administrator
Like this....
Perhaps a picture will help you understand things a bit more. Again, you are getting hung up on one point on the cam (lift @ .050) vs the whole lobe (which is a common mistake). So, lets look at this 256 lobe .
BBC lobe 3358 on a BBC core is 254 degrees (goes to ~256 on a LS1) lift @ .200 is 163. Gross duration is 310. Lift with a 1.7 rocker is .575
Now lets compare that lobe to the 'ultra mild' 232 XE-R. I mean come on its 20 degrees smaller. Its a baby lobe right? You tell me...
The XE-R 232 lobe is 232 @.050 153@.200 and 281 gross with .595 lift w 1.7 rocker
Lets look at the 242/242 106LSA 105 ICL (Aussie cam)
Lets compare a 242 BBC Marine lobe to a 242 XE-R lobe
BTW, the blue line is the BBC lobe.
As you can see, bigger in one part the same in others, and smaller somewhere else... Does this help?
Old Jan 24, 2005 | 02:46 PM
  #93
jrp's Avatar
jrp
SN95 Director
ya, if i can get a base tune on it sometime this week im hoping to fire it up this weekend.
oh and @ pro fabs K-member
Old Jan 24, 2005 | 02:59 PM
  #94
66deuce's Avatar
you know almost everyone on this board is dying to find out what you dyno with that custom cam.i think Ed will get some more business when you finally post your numbers.
Old Jan 24, 2005 | 03:10 PM
  #95
jrp's Avatar
jrp
SN95 Director
lol no ****. its taken a long *** time but sans the shortblock i did all the work myself.
Old Jan 25, 2005 | 12:10 AM
  #96
CamTom12's Avatar
That's definately something to be proud of
I'm just curious to see it run, it's been so long in the making
Old Feb 15, 2005 | 08:17 PM
  #97
GrannySShifting's Avatar
Im bored wanna take a wild guess duration at .006 is 290/292? .200 something like 157/155? pm me if Im close. doesnt do me anygood my heads are nothing like yours, just bored, playing with numbers
Old Feb 15, 2005 | 10:12 PM
  #98
HumpinSS's Avatar
Old Feb 15, 2005 | 10:37 PM
  #99
DavidNJ's Avatar
Which Performance Trends program is the graph from?
Old Feb 16, 2005 | 01:49 AM
  #100
You can keep Humpin, but she wont come for you
