Stall/Cam Question
Old Nov 10, 2004 | 09:45 PM
ChitownLS1's Avatar
Question Stall/Cam Question
What would be the recommended stall to run with a TR 224/224 114LSA cam on a daily driven 2004 GTO?
Old Nov 11, 2004 | 07:57 AM
Bo White's Avatar
Run what ever name brand 3000 converter you want. I see some people running even more stall than that on the street, it just depends on what your goals are.
Old Nov 11, 2004 | 08:06 AM
Rays C5's Avatar
I would use a 3500 .After 3 weeks its going to feel like it should have came that way. Might require some pcm tuning but well worth it!!!!!(setting codes)
Old Nov 11, 2004 | 08:19 AM
GregWS6&z28's Avatar
3500 yes
Old Nov 11, 2004 | 08:31 AM
XTrooper's Avatar
What's the rear gear ratio in an A4 GTO? If it's 3.23 or lower (higher number), than I'd go with something in the 3200-3500 stall speed range.
I had a Yank TT2800 and later a Yank ST3500 in my 3.23 geared '99 Camaro SS and first a Yank 3000 and now a Yank SY3500 in my 3.15 to 3.73 geared Corvette, so I have some experience with aftermarket converters.
Old Nov 12, 2004 | 05:47 PM
Rays C5's Avatar
Trooperx..... 2.x 60times..... ...sticky tires. I'd like to see how much your ets
would drop!!!!
Old Nov 15, 2004 | 11:32 PM
ChitownLS1's Avatar
3.46.
Old Nov 16, 2004 | 07:10 AM
68birdls1's Avatar
i would say a 3500 stall. if you have the money then go with yank!
Old Nov 16, 2004 | 07:42 AM
PREDATOR-Z's Avatar
It is not only the stall but also look at str and shift extentions.
would say ST3500 Yank or VIG 2800
Old Nov 16, 2004 | 08:58 AM
68birdls1's Avatar
but they dont make the st3500 anymore do they? i think the only place you can get those are from people sellin them right? or is yank sellin them again?
