Best Oil Filter?
Old Nov 14, 2004 | 05:26 PM
hc_performance's Avatar
Default Best Oil Filter?
What does everyone use? I have been using the Napa nascar select. Maybe there is a better one out there?
Old Nov 14, 2004 | 05:59 PM
68birdls1's Avatar
how much does that cost?!? i like fram!
Old Nov 14, 2004 | 06:03 PM
I think I paid 5.09 with tax.
Old Nov 14, 2004 | 06:10 PM
98boxer's Avatar
I have gotten differnt oil filters the last 3 oil changes so this is good to know which is better. Of course if the oil filter does its job and traps the dirt etc. it could eventually clog up the oil filter then doesn't the engine avoid the filter?
Old Nov 14, 2004 | 06:15 PM
snake charmer's Avatar
not saying this is the best but I use the mobile 1, it cost more than the fram but it matches my oil.
Old Nov 14, 2004 | 06:16 PM
Classic's Avatar
Normal Fram filters are about the worst thing you could put on your car. The HP frams are good though. Most people believe the Wix filters are the best (thats what that Nascar Napa one is -- just relabled).
Old Nov 14, 2004 | 06:29 PM
conan's Avatar
Is there any thing wrong with the stock ac delco or the longer version ac delco ?
Charles Cyrus's Avatar
I like K&N, they are easy on, easy off.
Old Nov 14, 2004 | 06:32 PM
LoPeY's Avatar
I use the HP Fram, they're cheap at Wal-Mart.
Old Nov 14, 2004 | 06:40 PM
BOWTIE's Avatar
From what I have seen the Fram's are very restrictive so most of your oil ends up bypassing the filter through the bypass valve. The most readily available filter that filters well yet is not overly restrictive is the K&N filter. Amsoil filters actually filter a little better without much added restriction, but are harder to find. Perhaps Patman will chime in here... he sent me a link a while back that compared filters, but I lost it.
Old Nov 14, 2004 | 06:49 PM
Patman's Avatar
Here is a good oil filter study:
http://www.oilfilterstudy.com/
I like the K&N the best. I've gotten excellent oil analysis results using these filters too.
Old Nov 14, 2004 | 06:53 PM
8UR SVT's Avatar
K&N is definitely a good filter, about $8. Mobil 1 is also a good filter for about the same as the K&N.
Don't buy the cheap fram or purolator if you are using synthetic oil. If you are paying for good oil use a good filter.
Old Nov 14, 2004 | 08:25 PM
DaddySS's Avatar
The last study I saw showed that the A/C Delco is one of the bettter filters and Fram was one of the worst.
Old Nov 14, 2004 | 08:26 PM
Cefiro's Avatar
I use Mobil 1's, but I have heard really good things about the long K&N's.
Old Nov 14, 2004 | 09:24 PM
good link!
Old Nov 14, 2004 | 10:01 PM
BOWTIE's Avatar
The Mobil1 fiter used in the comparison on the link above was almost 2X as restrictive as the K&N and Amsoil, with the filter medium itself being over 50% more restrictive. This means that even if it filters just as well as the other (maybe a little better than the K&N) it will still allow much more oil to bypass the filter altogether and go unfiltered.
Old Nov 14, 2004 | 10:13 PM
RevGTO's Avatar
Pontiacerator
K&N 2006 - the long one.
Old Nov 14, 2004 | 10:17 PM
Ferocity02's Avatar
I use the Mobil 1 filter. I buy the long one and not the short one it says to use.
Old Nov 14, 2004 | 10:29 PM
01SLPSS's Avatar
I use AC Delco PF59 in my 4.8, 5.3, & 5.7 LS1's, and for added protection I also use a FILTER-MAG!!!!
