cam for cali?
Old Nov 18, 2004 | 01:41 AM
Ferocity02's Avatar
Originally Posted by VaNDaL*SS*
i was also wondering about the 224/114 with p/p heads and later down the line i am thinking of some sort of F/I would that cam and the p/p heads work fine with F/I??
I always thought aftermarket cams didnt work too well with F/I. It will probably be fine thought since it's not too big.
Old Nov 18, 2004 | 01:54 AM
VaNDaL*SS*'s Avatar
it would require good tuning i bet?
Old Nov 18, 2004 | 02:10 AM
Casperws6's Avatar
any cam will benefit from a tune
Old Nov 18, 2004 | 02:13 AM
VaNDaL*SS*'s Avatar
yeah i know that i am saying that if i ever go F/I i will need to tune it really well. even for that small of a cam...also if i do the p/p heads and cam how much do you think i will gain with these mods i have ( i know they are not much )
Old Nov 18, 2004 | 07:17 PM
XpEdItIoUs's Avatar
If you want to go with F/I i would get a split cam for example the TR 224/227 114 LSA and i would go with lower compression heads and get thicker head gaskets. If you want to boost higher you need to have a lower CR, I heard some 6.0 liter heads work well with F/I.
Old Dec 17, 2004 | 01:29 PM
LIL SS's Avatar
Moderator
Originally Posted by Ferocity02
I'd get the cam from Thunder Racing. They seem to do a nice job, very high quality. Comp is the only other company that I know of that makes that size. Or, just take the specs and go anywhere and have a cam custom ground.
The cam sounds good, especially with the open cutouts
Hey man.. Nice Y-pipe, wonder where that idea came from Actually I like the way your driver side came out a little better than mine. Glad to see you put extensions on it like I did.
You have any back to back dynos. I am curious to see how they look compared to mine. Since you used almost the exact same parts I did. Only real difference are the cats you went with.
Isn't it great playing with the dual cut outs going down the road.
Old Dec 17, 2004 | 05:26 PM
SmaknaSS's Avatar
Originally Posted by Z28Venom
Stick with the TR224 114LSA to be certain of passing smog...
and you can pass with this cam and ported heads.. ED Blown Vert is a good example..
Or run the biggest cam you want and change it out at smog time. I't aint that hard in my opinion.
