Odds of bending pushrods on a 2-1 missed shift?
The reason I ask is my car dynoed pretty low for being blown, BUT I don't have any abnormal valvetrain noise.
Any insight is not only appreciated, but encouraged
Normally I would say the odds are about 1 out of 10 or so.
It is a somewhat common thing that happens, and sometimes you get unlucky and break ****.
Also do these pushrods typically bend enough that if I simply pull the valve cover I can see the bend? Or do I need to go the full nine and pull them and check them out?
~Rob
Just pull the rockers and check the pushrods. It'll save you a lot of time.
If no luck with that, do a leakdown test, that'll pinpoint the problem.
in all honesty it takes a little more than youd think to bend them, the big question is did you get back on the clutch soon enough.
i've too done it, and feared the worst, you best bet is to roll them on a known flat surface, Glass works well and watch for wobble or runout..
good luck if you need any help give me a call..
Later,
Greg
~Rob
PS how many of you guys follow the sequence for torquing them down then rotating the crank 360 and torquing the rest like the manual? Just curious if this step is even necessary?
