Disadvantages of a long stroke
. i dont think he's done a prototype LSX deck plate yet.
But what about clearance? I never really paid attention, but can you comfortably take off the valve covers if they were 1/2" higher?
lol you'd need custom headers or you could bent the crap out of whatever ones you have.... Hey I never paid any attention, but does anything mount on the driver side head?? I know on mine, theres the air pump on the pass side, but I dont remember if the driver side has any brackets with a mounting point on the head....
. The problem about strokers is the more stroke you run on a given block the lower the ratio will be because the block is only so tall.What does the piston look like with a stock sized 6.098" rod or 6" rod for a 4.125" stroke in an ls1. Just curious as I may try to convince APE to build something like this for me. The idea is the piston will not stay around top dead center very long which is good for warding off detonation in a high compression motor.
Giving up cubic inches is stupid. If I had my way I'd have the biggest bore and the biggest stroke I could possibly get. More CID = more HP. If you have to get cubic inches by using a bigger stroke, don't be afraid to do it.
Let's say that we want to build a 6.0L engine, and we've decided the max bore size we feel comfortable with is 4.03". Now most people would throw a 4" crank in it and call it a day. Why not throw a 4.100" crank in it? You get more CID and you turn less RPM (Assuming you use the same induction system as the 4" stroke engine). And don't forget what RPM stands for: Ruins People's Motors.
This discussion really needs to be about piston speed. Cylinder heads don't respond to Stroke or RPM by themselves, but piston speed, which is the combination of Stroke and RPM. True engine builders can relate pistons speeds to pressure drops on the flow bench. A port and valve job that looks good at 28" H20 might not look that good at 35" H20 (Speaking of turbulent flow, not laminar). This is all propriatary information, so don't expect a true engine builder to just give you the information he's gathered from years of standing in front of his flowbench, behind the controls of his dyno, and looking at his timeslips. Your best best is to give them your money, tell them what you want, and let them work their magic.
This is all pretty basic stuff...
My sources say, pay more attention to bore/stroke than rod/stroke.
Rod angle doesn't change much with a longer con-rod (Do the math),
therefore piston speed can't be that different.
"Side loading" seems to be a loose concern.
N/A applications tend to favour the "extra" hang time at TDC, but
how much gain for the swap? LSx 'fast burn' chambers probably wont enjoy that.
How about during the overlap period when scavenging is tailing off...
the exhaust valve begins to close and the piston is not moving much.
Does this tend to hurt the incoming charge as the pressure remains
relatively higher?
Longer rods tend to be a touch heavier.
I don't see much to support the longer rod craze.
The 'fast' chambers isn't referring to anything but their effeciency. They don't need a lot of timing to make maximum power. The high-end SBC and BBC heads are the same way.
relatively higher?
