Wanting to build a 400ci ls1, ideas?
Old Nov 23, 2004 | 10:22 AM
git_sum's Avatar
Default Wanting to build a 400ci ls1, ideas?
I'm in the process of getting a block and already have a set of 5.3 heads. I want to run a 11 to 1 compression ratio. What kind of bore/stroke combo would i need to go 400ci, or 6.4liters. Also is paying an extra $1200 worth it to get the Lunati crank versus the Eagle? Or what about the Callies crank? I want to run Oliver Billet Rods and JE Pistons, but also i'm not sure if the $1300 for the Oliver Rods are worth it. Any ideas/suggestions/combos would be appreciated.
Old Nov 23, 2004 | 01:02 PM
gollum's Avatar
4" bore + 4" stroke = 400 (talking about square ratio)
Jegs sells complete balanced Eagle kit part # 356-b12822+030 for $2279.99 + 8.99 handling charge. This is a speciel order. But they do have the 383 ( 3.905 bore+ 4" stroke) kit in stock part # 356-b12804. Same price.
To keep compression under 11to1 in 408 I would use Patriot LQ9 castings $1400.00 or big chamber AFR 225 $2400.00
Old Nov 23, 2004 | 01:08 PM
thefast1's Avatar
i thought a 4-4 combo was a 402
Old Nov 23, 2004 | 01:09 PM
gollum's Avatar
Close enough.
Old Nov 23, 2004 | 01:22 PM
JS's Avatar
JS
I believe the 414CI is the best rod ratio/piston speed combo but I could be wrong.
Old Nov 23, 2004 | 10:43 PM
family sedan's Avatar
If I was to build a motor now it would be a LS2 with a 4 inch eagle rotating assembly. I bet money that this will be the next big thing.
Old Nov 23, 2004 | 10:50 PM
WS6FirebirdTA00's Avatar
im wanting to build me something good. how much would it cost to build up a bottom end? with and without the block??
Old Nov 24, 2004 | 12:28 AM
git_sum's Avatar
Yeah but i don't have the xtra money to sink into a ls2 block, and that doesn't count all the other stuff that'll be needed. I guess i'll just be old school and go with the ls1
Old Nov 24, 2004 | 01:04 AM
Gloveperson's Avatar
That is what I have heard as well.
I have heard a lot of good things about the Lunati crank..if you have the money...it would be a good invesment!
Old Nov 24, 2004 | 06:38 AM
PREDATOR-Z's Avatar
422
Old Nov 24, 2004 | 07:19 AM
CamTom12's Avatar
Originally Posted by PREDATOR-Z
422
having an optimal rod ratio would help with durability/longevity, right?
so was it 414 or 422?
Planning a stroker in the near future
Old Nov 24, 2004 | 07:36 AM
how is that figured out?
Old Nov 24, 2004 | 10:04 AM
JS's Avatar
JS
I talked to few guys that build race engines...
414CI was optimal.
I dont wanna Darton (JMHO) so if I did build a stroker it would be a C5R case.I'm going to find out the optimal rod/stroke to build an engine w/o going bigger than 3.905...
I think its gonna be around 365 to 375 CI.This way I dont have to worry about coolant problem,sleeves issues or anything else for that matter.U might think I'm nuts to build something this small but I believe I can make real good power w/the right combo,one things for sure my Head/Intake/Cr/Rod Length/Stroke/P.Speed will all be matched accordingly.
Now someone give me 4K to build a shortblock
By Brett Foote | 2026-06-04 05:00:17
