how to fix collapesed lifters
How long did you run it after start up? It will sound real loud for a few minutes and then should quiet down after that.
Also you'll need a tune, only then can you really determine. Also are all your cylinders getting spark? did you hook up all the coils correctly?.
I would like you to do the same with a high duration cam, just to see how it goes, that should be some good entertainment.
You simply cannot ignore tolerances and trq specs, and trying to convince others it is OK is typical childish and ignorant behavior.
Over half the problems posted on this forum come from poeple ignoring proper established techniques in building or swapping parts on their motors.
jmho
