Looking for a cam...
Old Nov 29, 2004 | 01:54 PM
baldurann's Avatar
Default Looking for a cam...
What cam would make the most power in my '04 C5 using stock heads?
Old Nov 29, 2004 | 02:07 PM
SouthFL.02.SS's Avatar
!LS1 11 Second Club
TRex cam. Thunder Racing.
MS3 Cam. Texas Speed.
F14. Futral
G5X3 on 114lsa. LG Motorsports
Old Nov 29, 2004 | 02:18 PM
cyphur's Avatar
South, you think the -14 will outperform the RJ? I'm installing the 14 this spring, figured I'd be 5-10 shy of the RJ.
Old Nov 29, 2004 | 02:23 PM
!LS1 11 Second Club
Have you seen the advertised rev range of both? I'd go with the F14's range on a stock bottom end. It's already pushing the limits as it is. RJ would be unuseable IMO.
Old Nov 29, 2004 | 02:43 PM
!LS1 11 Second Club
Just read MTI's Y1 cam thread. Looks mean.
Old Nov 29, 2004 | 02:59 PM
baldurann's Avatar
And just an FYI, I am about 20 minutes from MTI so ordering one of thier cams would be super easy.
Old Nov 29, 2004 | 03:02 PM
MachoCamacho's Avatar
yay! another person obsessed with power!, they have discovered 420 rwhp out of TSP torquer and FM13, but the MOST power will come from t-rex probly.
Old Nov 29, 2004 | 03:03 PM
!LS1 11 Second Club
Y1 link
Looks great. I wish I lived 20 minutes from MTI!
Old Nov 29, 2004 | 03:46 PM
baldurann's Avatar
I wonder how much adding a big cam will compromise drivability?
Old Nov 29, 2004 | 04:47 PM
!LS1 11 Second Club
With proper gearing and a good tune, should drive fine.
If you have an A4, you'd need a new stall converter.
Also, bolt-ons come first. Make sure you're running Long Tube Headers before the cam install.
Old Nov 29, 2004 | 05:17 PM
baldurann's Avatar
I have a m6, and sounds good! thanks
Old Nov 29, 2004 | 07:26 PM
cyphur's Avatar
Yes I've seen their rev ranges, hence why I'm not about to install the RJ. My motor isn't going into the 7k range. I'm not thrilled with 6800+ but ARP pro series rod bolts should take care of that for 10k-15k miles. I dont' track this car much so I'm not terribly worried about it. It won't see 6600+ on a daily basis so my motor shouldn't explode too soon. When it does, time to upgrade
