question about piston rings
Old Dec 7, 2004 | 12:34 PM
kumar75150's Avatar
Default question about piston rings
How much rwhp and tq can one expect to lose if going with a pretty nitrous specific ring set?
I went with a G2000 ringset on my new motor and the dyno numbers are lower than I expected and I am trying to see if thats part of the reason.
Old Dec 7, 2004 | 04:52 PM
kumar75150's Avatar
any engine builders want to chime in about the G2000 ringset and if it costs any power on the motor?
Old Dec 7, 2004 | 05:44 PM
BTL FED's Avatar
What are your ring gaps?
Old Dec 7, 2004 | 06:12 PM
kumar75150's Avatar
i need to talk to my builder and find out the exact gap
they told me before hand that i would lose the most power with the hellfire rings and second most with these C&A g2000 rings
just wondering
Old Dec 7, 2004 | 10:59 PM
Redline-Motorsports's Avatar
I don't think it's enough power to go crazy over. Everyone thinks they got to run low tension rings on N/A motors to make "big" power and they just lead to oil consumption.
If you are running a spray motor set it up right!
Old Dec 8, 2004 | 12:51 PM
Chris@AP-Engineering's Avatar
Under criminal investigation for fraud
It really is all going to depend on your ring gap. If your gap is too big or set up for a lot of nitrous you could be down a little on HP when running on motor. You won't be missing a lot of HP though. Also generally the G2000 rings and the Hellfires come with standard tension oil rings. This maybe taking somepower away from you but, like Howard said, it's not enuff power to go crazy over.
Old Dec 8, 2004 | 12:55 PM
Slow Z28's Avatar
Spray more through it
Interesting discussion though.
Old Dec 8, 2004 | 01:13 PM
kumar75150's Avatar
ya I'm only down about 15hp or so from where I wanted to be. Its still well over 500rwhp.
Combined with the rings, I think I am also getting some valve float after 6400rpm. Gotta take care of that alos.
