Weight difference?
Old Dec 8, 2004 | 03:32 PM
LASTLS1's Avatar
6 Second Club Moderator
Default Weight difference?
Whats the weight difference between the alum and iron block? Thanks
Old Dec 8, 2004 | 03:38 PM
GuitsBoy's Avatar
most people say 80 Lbs
Old Dec 8, 2004 | 03:47 PM
777's Avatar
777
yea something like that...i'm sure you can search google or something and you could find the weight differences....
Old Dec 14, 2004 | 07:13 PM
LS1CamaroGuy's Avatar
I've "heard" it was more like 110 lbs. but thats just hearsay.
Old Dec 14, 2004 | 07:23 PM
SPANKY LS1's Avatar
"Valvegod", who sells and ships both, says there is 107lbs difference, between a LS1 block and a 6.0 block, both with main caps and bolts....
Shawn
Old Dec 14, 2004 | 08:43 PM
jrp's Avatar
jrp
SN95 Director
in my FAQ's i've got the weight difference as stated by GM.
Old Dec 14, 2004 | 10:01 PM
Nate_Taufer's Avatar
its 93 lbs for just the block alone. with mains and bolts i wouldnt know.
Old Dec 14, 2004 | 11:06 PM
bfly's Avatar
this is a quote from JRP'S FAQ'S
The LS1 block is made of 319 aluminum heat-treated to the T5 standard by the Montupet Corporation of Ontario, Canada. It is cast using the semi-permanent mold technique which Juriga described as "....a cross between die-casting and sand-casting." The case weighs 107 lb. Compared to the Gen III's 210.4 lb. block, thats a significant weight saving
