383 Owners please check in..
Old Dec 9, 2004 | 05:55 PM
fastbasser's Avatar
Default 383 Owners please check in..
I have been using the search and checking what is being used for cams in these motors. I have spent alot of time on the phone with vendors as well. Some suggestions seem alot bigger than I would have thought.
I realize you can go to a bigger cam when adding cubic inches..
With an A4, daily driver, whats the real limit?
Thanks guys.
Old Dec 9, 2004 | 07:57 PM
Bo White's Avatar
If you still have that Comp 224 just stay with it unless you want something more aggessive. I just finished one up that has a 238/240 shaft in it so daily driver is a relative term. There are plenty of threads about this so keep diggin'.
Old Dec 9, 2004 | 08:45 PM
Reboot's Avatar
I'm running a 232/236 .575/.578 114 LSA and it lopes, but not too bad. I wouldn't want to go any bigger (I'm too old to deal with driveability issues).
It just made 489.3rwhp/480rwtq last week on the dyno. Although, I did have to spend a lot of $$$'s on all of the goodies getting there.
Including:
TEA ported AFR's 2.05/1.57 64cc 10.7:1 compression
LSX/NW 90/90
Kooks 1 7/8 headers
Exedy Twin Disk Clutch
My motor peaks at 5800rpm's and holds above 480rwhp until 6500rpm's. It makes over 450rwtq by 3900rpm's (not too shabby for a baby stroker cam).
Good luck with your setup
Old Dec 9, 2004 | 09:19 PM
black_knight's Avatar
The limit, as I understand it, is on your hydraulic lifters and not on streetability when you go big cubes. I could be wrong, though...
Old Dec 9, 2004 | 09:56 PM
WicketMike's Avatar
Including:
LSX/NW 90/90
Kooks 1 7/8 headers
are you able to pass smog here in cali? how big of a cam can you go with a 383 and still pass smog?
Old Dec 9, 2004 | 11:04 PM
Reboot's Avatar
Hahaha! No way in hell it will pass the sniffer without friends in smog places. I think the biggest you can go safely in cali and pass is 224/224 - 226/226 with cats.
Old Dec 10, 2004 | 02:14 AM
Visceral's Avatar
I had a 230/228 on a 114 and it was almost stock... as far as I remember stock anyways. Even though I'm also an old fart that doent want drivability issues, I went with a 236/236 112, though I had asked for a 114 LS. Guess they didnt hear right. Anyways, the thing is a little much for me. On the other hand, peak power has moved from 5600 to 6000. So I like the general 236ish size for a 387 all-bore. I may try to run a G5-X3 on a 114 soon if some more computer programming doesnt sew up the drivability. I've come to the conclusion that a 383 stroker can take a little more cam than a 387 all-bore given a certain drivability... so your mileage may vary, but it's close.
Fortunately we dont have sniffer tests for newer (obd2+) cars here. They just plug em in a look for codes. No codes, its on to the noise test (woops!).
I will pass the test as soon as I get a plate thrown in the exhaust to pass the noise test. Im currently 13dB over ...and I don't think its all that loud.
Old Dec 10, 2004 | 09:45 AM
SSean's Avatar
A friend of mine locally, ttech1ta I think here on the board has the same cam I have listed in my sig, in his 383 with a built auto, on a nitrous tune (running pretty rich for a 300shot) Hey put down 465rwhp (N/A of course) Other mods are ported LS6 heads, that I think are a few years old, and QTP 1 7/8" headers. Don't really see our cars passing a smog test though
Old Dec 10, 2004 | 10:24 AM
WicketMike's Avatar
224/224 is the biggest you can go on a stock LS1 and pass smog, but what about a 383? the same?
Old Dec 10, 2004 | 10:31 AM
Reboot's Avatar
It has to do with overlap and not engine size.
Old Dec 12, 2004 | 09:39 AM
383ss's Avatar
I had a 236/232 .602/.575 112lsa in my 383 as a daily driver. made great power at 475+ was very drivable and sounded great.
it's also for sale if you are interested
