NY emmisions test..
Old Dec 12, 2004 | 08:24 AM
fastbasser's Avatar
Default NY emmisions test..
Is ours a sniffer or do they just check for engine codes??
Old Dec 12, 2004 | 08:37 AM
NOSjohn's Avatar
Restricted User
The 1996+ test, they check for codes.
Old Dec 12, 2004 | 02:43 PM
james99ws6's Avatar
the "emmissions" test is pretty simple. cars 99-01 will pass if there are no check engine codes present in the computer, or its memory. Along with that your computer has different monitors, you can fail up to two monitors and still pass.
on 01-up everything is the same except you can only fail one monitor. no sniffer or nothing
Old Dec 12, 2004 | 02:44 PM
someday's Avatar
it also checks the readyness, u can't just turn off a code/light and expect it to pass, it checks for drivecycles after the light was shut off
Old Dec 13, 2004 | 01:54 AM
jessesta's Avatar
do you guys know if o2 sims will fly with the new inspection
Old Dec 13, 2004 | 02:36 AM
family sedan's Avatar
They should if you have legit front sensors and sims in the rear.
Old Dec 13, 2004 | 06:28 AM
Ojustracing's Avatar
I guess It would depend on the shop. We still have to do a Visual to check for all installed emissions parts. Here's a quick note FYI. Alot of the shops have started to become **** about stuff, mine included. At my shop you would not pass. Later John
Old Dec 13, 2004 | 09:21 AM
fastbasser's Avatar
Thanks for the info guys. And to James99ws6 for pointing out my typo,,,,
I found the answer on the NYS DMV website.
http://www.nydmv.state.ny.us/broch/c-50.htm
One quote from the site...
"The inspection station is required to advise the Customer about the OBD check results, but cannot fail the vehicle's inspection based on those findings."
Old Dec 13, 2004 | 09:35 AM
That is not correct............................ That is wrong it has not been updated since 02 things have changed..... Do a search for NYVIP its on the DMV homepage....... Later John
Old Dec 13, 2004 | 10:20 AM
GuitsBoy's Avatar
NY metro area, long island, westchester and rockland counties all still have the sniffer, until they officially start the NYVIP OBD-II testing program, April 1, 2005. Upstate NY is currently running the OBD-II test as of Dec 1.
-T
Old Dec 13, 2004 | 10:56 AM
fastbasser's Avatar
Great info guys.
Old Dec 13, 2004 | 04:29 PM
james99ws6's Avatar
i wasn't correcting your grammar, i was calling NYS dumb for comming out with an emmissions test without a sniffer! oh well thats good for us who do not use cats!
Old Dec 13, 2004 | 05:12 PM
fastbasser's Avatar
James..
Only makin some humor about a BS topic! One we are all gonna have to be facing before too long!
Old Dec 13, 2004 | 05:45 PM
jessesta's Avatar
If you use a shop with a decent guy you might get away with it. The Place where I go said he wouldnt have a prob as long as he can do a quick visual and see that there are cats there.Its time for me to go to the junk yard and get some converter covers.
