Patriot Gold Springs Failing?
Originally Posted by V8er
This is good info and no doubt true, but maybe the small cams in the T1 cars are easier on the rockers than a G5X3, etc?
In general lifter failure is due to wrong preload (too much). Also lifter preload shoud be done ho and not cold, which results in too tight tolerances upon heat pump up.
Restricted User
I agree with getting stock rockers modified. Soon as I can get a spare set, from a YT or HS user, I will get some modded lighter, "stock" rockers!
Good luck and please post back your findings.
Charlie
Charlie
Originally Posted by WS6snake-eater
Just because you have broken one doesn't mean everyone else will! The point is, your case is a rarity.
Now of course it doesnt mean everybody is going to have a rocker failure...for the past 4 years I've used nothing but stock rockers, but at the same time saying it is a "rarity" is a stretch. It is a very well known issue and one that I've seen happen more often than a rod bolt let go (which I have seen happen).
My G5X3 ran very well with the stock rockers...But, it was annoying to listen to...TAP, TAP, TAP...7.35 pushrods, G5X3 and stock rockers, don't make for a good quiet combination...
I added a set of CraneCam's Gold Adjustable Roller Rockers and they really feel as though they rev the engine much more freely and smoothly...Seat of the pants feels better down low and stronger up top right up to the 6800 rpm rev limiter...
ALSO...NICE AND QUIET...
Peace...Gman
Peace...Gman
