ARP Main Stud question
Old Dec 20, 2004 | 02:55 PM
james99ws6's Avatar
Default ARP Main Stud question
Is it true that when you install ARP main studs in the block that you will require an align hone? How can these studs throw off the clearances? Is there anything else i should know about installing any type of studs in the motor?
Old Dec 20, 2004 | 02:59 PM
Boostaholic's Avatar
There are threads about rod bolts throwing the caps out of round, it is true that it can throw it out of line, far enough to require machine work though I don't know.
This is also the reason I have not installed a main girdle, because I don't know if it will throw it out of line enough to matter.
Old Dec 20, 2004 | 03:52 PM
james99ws6's Avatar
i am getting prices for anywhere from $175-$275 just for an align hone. i am not going to cheap out if needs it, but now im looking at $151 for main studs, and $175-$275 for an align hone. damn! just to spin it up to 7000rpms.
Old Dec 20, 2004 | 04:36 PM
Viper's Avatar
Pay to Play
And
He who has the deepest pockets goes the fastest
Old Dec 20, 2004 | 05:14 PM
strokedls1's Avatar
I did not do it on my iron block. Had them check it out while doing all the machine work and it didn't need it.
