help! installing harland sharp 1.8 rockers in my 6.0!!
anyone know what size push rods i need?(how long). i installed them and my stock one are too long, not letting the valve close. any help would bee great.
thanks
thanks
I have 7.350s in my truck, It is with the stock cam and lifters,It is a LQ9. I had too much preload with the stock pushrods, I went to the shorter rods to help with the preload. How much preload do you have?
honestly i don't know .i had a guy do it @ a ls1 performance shop install them. and all he told me is my stock were too long and i had to get shorter pushrods or shimm the stand of the rocker?.
I have them on my SS, It wasn't enough for me, If I were you I would just do a cam swap. I am changing my cam in a week or so,but I am going to use my rockers since I already have them. I would get a intake and a custom tune.Stay away from a handheld,they are no match for a custom tune.
You need pushrods or shims for the rocker to use those rockers.
The cost is around $500 then after that all of your upgrades are free, If you add more mods he will sent you a updated PCM, you just pay the shipping. Some of the others are cheaper but, you have to pay around $50 for upgrades, He gives you a awesome tune, I am on my second,looking like I am going for my third after the cam swap.
Depends on your plans for the truck, If you are going to swap cams down the road then don't keep the rockers. If that is all you plan on doing then keep them, They will need shorter pushrods, I would not shim the rockers, this may put them into the valve covers.
