What is acceptible Engine Mileage?
The mileage obviously affects the price, so how much weight do I give to engine mileage? The car this motor will be swapped into is only driven about 3000 miles a year. The motor may see some performance mods, but not for serious racing. I will take the car on some trips so reliability is important to me.
All that being asked, what are the weak points and parts that show wear? Are there motors that are more desirable or ones to be avoided? How about the Automatic transmissions? Do they last as well as the motors? Do they perform well stock or do they need to be modified for performance street use?
I have got books coming to help with my education so I won't have to be asking everything, I really appreciate your sharing experience and knowledge
Pat
click the FAQ in my sig, its got all the basic ls1 info you want/need (engine wise). the 4l60e is a pretty stout tranny, i'd wager you'd have no problems with basic bolt on mods. what rear end are you going to use?
Now for my rear-end, it currently has an 8 inch Ford, 28 spline axles from a Maverick. Chosen for its stock narrow width. It has 2.79 gears, non-posi at the moment. One of my upgrades will be lower gears and a limited slip. My pre-LS1 plan was to go to 3.80 gears with an overdrive automatic. My tires are pretty tall by your standards, 29", so the 3.80s would be comparable to 3.55 or 3.42 with shorter tires. Given the overdrive and the limited miles I drive I could even go to 4.11. While the 8" Ford is not bullet proof I believe it to be at least as strong as the stock Z-28 rear-end. Given my intended use it should hold up. If I start breaking it, well then hello 9 inch.
Thanks again for the good info and for your work on that FAQ
Pat
Pat
. rod bolts on the 98-99 and early 00's are a weak point but since you said you dont drag race or plan for big mods or RPM i dont see that being a problem. mechanical overreving and bending pushrods is also common (m6) but thats more of driver error
and since your going with the auto i dont see that as a problem either. just about anything is better then the GM 10 bolt
Glad you liked the FAQ
Derek
