autozone/sears spring compressor question
SN95 Director
i prefer the TDC method over the air compressor myself. the compressor is to cumbersome. i compress the spring and then use a pen magnet to make sure the valve is all the way up then drop the locks in. friction holds the vavle up long enough so it doesnt slip down.
to answer the question about the crank seal, its one piece. you tap the metal part to get it out. tapping the rubber just pokes holes into as you found.
oh ya, my lost lock ended up on under the steering wheel shaft on the k-memeber. i found it months later. might want to check your header too, a local guy i helped out during his swap lost a lock and it ended up stuck on bewteen 2 primaries near the collector.
blkz28spt: I was so worried about dropping a keeper in my motor I took a clean tee shirt and put it on my head all around the springs. Your probably ok, it fell on the k member and dissappeared. I found a clip that I lost from my tranny line over the summer on my k member when I swapped my springs.
JRP: thanks, guess i'll try pounding on the metal. I am now to the point of reinstalling the timing cover.
The K-member eats a LOT of things. I dropped my first 10mm gear wrench in there during header install and never even found it.
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
SN95 Director
![Icon Eek](https://ls1tech.com/forums/images/smilies2/icon_eek.gif)
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
how'd lining up the dots go?
Originally Posted by jrp
you lost a whole wrench
, the k-member is like a black hole. one reason i replaced mine with tubular one ![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
Lining up the dots went a lot quicker than I expected. Like the second try it was really damn close. We guestimate it looked like it was 1/4 tooth off but could be right on with the small amount of slack in the syestem. The car is 100% back together as far as I know. BUT since it's 3:35 am and everybody else is in bed.........I've worked all day since 11 am (when my kickass crane cams spring tool came arrived).........and I'm only 99% sure I did everything I am waiting until tomorrow to start it up so that I can double check everything, my dad can double check everything with me to try and spot something I may miss, and someobdy can watch fluids for me. GD I'm tired. Went from having only two springs installed to totally finished in one day. I think taht went alright
I'll start a new thread once I get it started and I have a small list of recomendations/tips/etc on what ended up working for me.
SN95 Director
I'll start a new thread once I get it started and I have a small list of recomendations/tips/etc on what ended up working for me. ![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
Congrats man. Lets us know how that crane tool worked out for ya. Did you end up using compressed air ?
Please do share anything that was worth noticing...I'll be doing my cam swap in a couple months. It's still too cold here in chicago area. Even in garage.
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
I threw out my Autozone spring compressor. It sucked *** for spring swaps on the car. Got tired of retainers and locks exploding everywhere if the tool wasn't lined up perfectly. I ending up making a tool like I saw on here somewhere. It's just a piece of steel bar that bolts on it place of the rocker arm. Tighten it down and tap it a little to free the locks. It leaves you two hands free to work while the spring is compressed.
