comp r lifter issue
Old Dec 30, 2004 | 06:34 AM
jason5's Avatar
Default comp r lifter issue
i used the comp r lifter for my rebuild, and set the preload according to comp cams on hot settings, no more than a 1/16th of a turn, they told me they would chatter too. but the werdiest thing is, when the car has been sitting for awhile and i start it up, you cant hear a peep out of them, they are qiet and you can here my cam loping, but when the car starts warming up then they start chattering, what would make them quiet on cold starts and start chattering when they are warm
Old Dec 30, 2004 | 06:52 AM
SAM98WS6's Avatar
Sounds like everything is expanding and loosening up...
I would try the recommended .008-.010 preload cold and see if that makes a difference..thats about 1/5 of a turn...but measuring is better.
Old Dec 30, 2004 | 07:35 AM
jason5's Avatar
but when it warms up the cam sounds the same through the exhaust, just the valvetrain is louder, so i know i'm not losing my lift from my cam
Old Dec 30, 2004 | 08:21 AM
SAM98WS6's Avatar
humor me...im just curious and its easy to do is the correct thing to do. Curious to see if it does anything.
Did you remove the cosmolene from the lifters with mineral spirits and soak them in oil before the install?
Old Dec 30, 2004 | 08:42 AM
crainholio's Avatar
What rockers are you running?
Old Dec 30, 2004 | 08:48 AM
jason5's Avatar
yes i did,
i'll try it and see, this will be the 4th time i have adjusted these, i have gone from 1/2 a turn, 1/8, and 1/16, and 1/16 queiten it the most, but its worth a shot to see what 1/5 of a turn will do., is it possible why it is quieter on cold starts because the oil sits there and thickens up
Old Dec 30, 2004 | 08:49 AM
jason5's Avatar
comp 1.75 pro mag adjustable rockers
Old Dec 30, 2004 | 08:52 AM
SAM98WS6's Avatar
You arent hitting the valvecovers are you?
Can you measure with a dial indicator .008"? That is the proper way
Old Dec 30, 2004 | 09:18 AM
crainholio's Avatar
If this is a newly-rebuilt engine, with no runtime since the build, you're actually troubleshooting more than just the Comp lifters.
If that's the case, and the rebuild has only been run w/ the Comps, they're not likely the problem given that it's not responding to all the variations in preload you've tried.
So...how does your oil pressure look when it's at op temp and ticking? How comfy are you that the oil pump o-ring is righteous?
Old Dec 30, 2004 | 09:19 AM
jason5's Avatar
no i had to do some machining on the driver side valvecover but i fixed that, i'm using a dial indicator to mesure the preload, i'll try 1/5 toinight and see what happens
Old Dec 30, 2004 | 09:44 AM
SAM98WS6's Avatar
I had to modify both valvecovers.
might want to try grease on top of the rockers and see if you get any on the valvecovers.
Old Dec 30, 2004 | 02:18 PM
crainholio's Avatar
I'm still thinking this sounds more like the oil pump/pickup O-ring problem. It's a new rebuild, the Comp lifters aren't the only suspect.
