My rollmaster/oil pump install....new found experience
Rollmaster cam gear
I originally purchased a posi lock 104 puller model from sears but it didnt work for the ASP so I was already to return, however, it worked great on the crank gear. Popped off no problem. To reinstall the rollmaster cam gear I used the stock and a rubber mallet to "bang" it on.
Oil pump
I was getting very very frustrated becasue I couldn't get the pump to aligh to the crank gear (all the while putting pressure on the pickup tube) and could not get it the inerds to line up. So before I threw it across the room I came up with the idea to use the stock crank gear to set up the keys inside the pump (only works if installing or have installed an aftermarket and have the stocker handy). I kept it there and oriented the keys to match the new crank gear setting/position. At this point the pump is tilted a bit. I then pushed the the pickup tube low enough to clear the casting, started sliding the oil pump from the old onto the new. Worked pretty good
Pickup tube bolt
I stuffed one old Tshirts on the left side and another on the around the back of the pickup tube. Then I used aluminum foil to make a tray right under the bolt hole so it would be easy to grab if dropped. The Tshirts ran behind it and served as a good backing/buffer so I could mold the the foil into a cup. Otherwise I couldn't get it to form correctly. Then I wrapped solder around the bolt, put in the gearwench and then wrapped the solder around the gear wench. I actually had to take the wench out of the equation later on cause I couldn't get the bolt into the pickup hole (installed a double roller and clearence was tighter than stock) and then put the gear wrench on it. Still didn't work because the wrench wouldn't ratchet since there wasn't enough resistance from the threads yet so I used two fingers. While doing this I had to get creative with the prybars to get the pickup tube flange up to the pump. It seemed to work after time and alot of cursing. I have pics I will be posting later.
Bill
