Purpose of coating pistons? Heat? Detonation?
I am putting together a stock LS1 using stock pistons. If I can get the top of the stock pistons coated for a reasonable price, and it will help prevent detonation or help to protect the piston in the event of small detonation it would be worth it to me.
Would it be beneficial to do so? And if so, what kind of coating should I look into?
I'm not going with a forged piston. I dont want to spend the money on machine work and balancing. I just want to throw this together and blow 200-250 at it and see how good I can do on stock internals.
Distortion comes into play when a metal absorbs enough heat. If heat is reflected instead of absorbed, the object has a better chance of holding its form which helps keep clearances in check
It was originally used by the russians on their fighter jets but now we can do it. Instead of a coating sprayed or painted onto the crown it's actually embedded into the piston crown so can never fail or flake off. Be warned, it's probably expensive! In addition to the other posts above, heat in the combustion chamber represents expansion power. Heat absorbed my the head and pistons is lost energy. It will give you some extra leaway with detonation but won't stop a blow up if your engine's set up wrong.
Now the question is what kind of coating should I look into? Emphasis on inexpensive
How much am I looking at to take them to a reputable shop? (there is a piston manufacturer local to me) What do I buy if I choose to do it myself? Does it come in a can or something? Now the question is what kind of coating should I look into? Emphasis on inexpensive
How much am I looking at to take them to a reputable shop? (there is a piston manufacturer local to me) What do I buy if I choose to do it myself? Does it come in a can or something?Trending Topics
