patriot LS6 stage 2 heads.....is my piston to valve clearance ok?
im in the process of installing my patriot perf stage II LS6 heads. dont know if it makes a difference but the valves are 2.055 and 1.57. my car is 100% stock and I am re-using the stock rockers.....will my piston to valve clearance be ok?
Originally Posted by JoeyGC5
from the description, sounds like heads only. Shouldn't be a problem. ![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
sorry, yes it was a head only install and everything seems to be working just fine.....but while we're on the subject, whats the best cam to go with the Patriot LS6 stage II heads? Also, I plan to have nitrous installed on it sometime soon. maybe a 100 shot
PTV in your case should be fine. For a nice street set up, a lot of guys are running our 226/226 .585"/.585" cam or similar ones. Depending on the mods, they are seeing 410-430 rwhp.
