226/228 or 230/227?
as ive posted in here before, my 224/224 might need replacing so while im in there i just wanted to go slightly bigger.
i have all bolts on, slp lt's, tea 1.5 heads, 3600vig, 3.42 gears, and yada yada yada....
i was wondering which would make a tad more hp over the other. I realize HP gains wouldnt be more than 10-15, so thats no biggie... 7-10hp would be fine lol
my exhaust has the offroad pipe and cutout so its pretty free flowing with the cutout open
any ideas?
i took a look at the F11 cam... 228/230 and im diggin that one now
so many cams... so much info... cant make a decision
Intakes are sensitive to both duration and lift, however exhausts are mainly sensitive to duration.
If you look at the head flows, you will see the exhaust flatten at about .4". However, when it opens there is about 150psi behind it. When it is open on the exhaust stroke it is really all over.
The intake as a minimal pressure drop. So it is a matter of shrouding, port design, and valve curtain area.
Just my 2¢
David
Good luck with your selection!!
EDIT...compared to the FM11..
FM11---overlap=1...split=2
226/228---overlap=-1....split=2
Personally, i'd go FM11, but notice the lift is higher than what you originally wanted( fm11 is .576/.595)
thanks for the help.. ill do some more reading on the f11's tonight in here
