Where to get oil pump spacer for Roll Master chain?
Here are some traces I did for a member a few months back, they are from a Rollmaster double timing chain for LS1's.
![](http://www.ls1camaro.net/freehosting/rollermaster_shim_cond.jpg)
Excuse my crappy handwriting, but you get the idea. Apparently the traces worked well enough for him. If you want to search for the thread, I think the guy's name was 68bird. Hope this helps, I don't have the chain any longer so I can't make any more traces.
hey man, i went through the same thing that you did. ended up my cat took them out of the box that the chain came in and played with them. and then after about a month after i put the chain i saw the parts laying on the floor! lol i was so angry at that lil bastard. lol. but i made a set and if i can make them i know anyone can. i will look for the set that i have somewhere and all i will want is like $10. but let me see if i can find them first
Originally Posted by PREDATOR-Z
That is a good one Cyphur!
You have all the dimentions. please proceed and duplicate. ![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
Yes, i'll just go to the metal shop in my apartment and make them.
![Pissed](https://ls1tech.com/forums/images/smilies2/pissed.gif)
Please don't respond if you're not gonna answer the question for me, thanks. I do have somewhere I can get them maid, all I wanted to know is if they were a little off or didnt have rounded edges if something would get in the way of them fitting. geeze.
68birdls1: If you can find them i'll gladly pay you the $10. It would be much easier for me.
jermzz, cool down dude. i think the fact that i said "traces" in my original post, and that there were pictures of other original pieces should have spelled it out. sometimes people around here snap cuz a lot of people ask a lot of stupid unneccessary repetitive questions. yours may have had some merit, but realize the answer was also right here on the page.
my pics are EXACTLY what they look like. they are machined metal, no rounded edges except the shape. hopefully 68birdls1 can help ya out.
68birdls1...glad to see that helped ya out!! too bad about the cat, not much you can do about them. they're curious playful creatures. gotta luv 'em tho
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
I understand the dimensions are there, but the tracings are usless as they will not be the correct size when they are printed on paper. Hence my question I was flamed on.
Im feel you jermzz. Some people like to be condisending tards. Dont act like a genius then try to justify someone being iritated with your actions, answer clearly or dont reply. Some people are trying to get things accomplidhed here.
Guys, no flames here just wallbanging.
You have your oil pump. Flip it and you'll see where the holes are.
Make a template of the areas on the pump with pencil and paper
Put the template on 1/8 inch sheetmetal, draw the contour and holes. use the dimentions given to you as reference. smooth out the edges and voila.
In my basic little mind, I cannot fathom how one would do a cam swap and not be able to use their immaginations to fabricate a simple shim (with pics and dimentions given nonetheless).
So if I offended you little wet nosers, well tough. You should concentrate on learning not the offense. Obviously none of you have been in the Army.
(Ok that being said, it's obvious I'm not in a good mood)
Petty quarrals aside, the dimensions are there, you should be able to take that diagram to any machine shop thats worth half a damn and they should be able to make them. Like P-Z said, just flip over your oil pump and you should see where they belong.
David
The army is actually a bunch of brain washed overachievers that are taking the easy but hard way through school, that turn gung ho and arent given the chance to be questioning athority. But I have huge respect for them all at the moment, they make our world a better place. And I could care less about the whole situation, its not my car. As for your mood,I give 2 ***** about your mood, I just kind of saw the situation from jermzz's perspective. No harm ment.I appologize if I came at you all the wrong way. And the army comment is totally irrelevant. I have three friends in that **** hole, what does that have to do with ones opinion on a diagram. Also consentrating on the task at hand in the army is called attention to detail. But what must we know, we werent in the services. But thanks for the help you did give, as you can see my moods just fine.
In the Army they teach you how to use initiative, analize problems, resolve them very quickly (your life depends on it) and how to "think out of the box". That is what I meant.
This problem solving logic is very helpful in daily life and especially in the Hot Rodding arena, where everything has to be modified or fabricated.
As for your other comment about what an army is, I will ignore it since you have obviously NO idea and certainly have not deserved the right to make a comment like that.
Just remember that in order to have peace, you have to be ready to go to war, and that requires an army.
My dad was in the vietnam war, grandfather in ww2, and by the way I voted for bush and respect what were doing and support it. If anything comes out of this war, its that genocidal world terrorist threat no longer ahole saddam is no longer in power. And Ill be the first to say to anyone on this thread who was in the service, I respect you and thank you again. I didnt mean to offend anyone,if I did i appologize. But leave the army stuff out of the car forums if at all possible. Because we both know and im sure you would honestly agree, there are some guys in the army that follow orders about as well as a great white shark,and have the i.q of a camshaft.
