What Cam For Stock Ls1
dont talk about what you dont know! i will have some proof within a week about how well the hotcam works!
dont talk about what you dont know! i will have some proof within a week about how well the hotcam works!With Cam
springs
pushrods
timing chain
pcm tune
headers & catback
valve stem seals
rocker arms
oil pump
pulley
differential gears
lifters (inspect and replace if necessary)
ported throttle body
ported heads
heads milled for higher compression
And no matter how good the spring, revving over 6000RPM causes massive heat buildup in the springs themselves. Deterioration is inevitable.
JRP is saying this?
as for you check the cam guide in my sig for the basics.
