Opinions on Hot Cam...
I used think the hotcam was a good idea until I got a more aggressive cam. Now Im glad I didnt waste any time with the hotcam.
I say that if you can get it for cheap go for it but if not I'd get something else.
LS6 or LS1 Hot cam?
I have the LS6 Gen3 Hot cam.
I'll be sellin it here soon for like 200 bucks when I buy a ligenfelter gt2-3 cam.
LS6 or LS1 Hot cam?
While the debate goes on, the Hot Cam is a pretty good choice for a cam only motor. It has a nice ramp rate, so it's not that hard on the valve train. It has a KILLER idle! And it has a longer exh duration that complimetns the smaller vavles & lower exh flow rates. And you can see in my sig that 400rwhp is not out of line with one. True, I have 1.8 rocker arms, but 392 thru an A4 is not bad with stock heads.
That said, it does offer challenges to make it idle right, especially with an A4. But it CAN be done. And once I get my stall converter in, I should be knocking on the 11 sec range. Again, for up here in Seattle, that aint too shabby.
But you can put in a cam that will perform as well. The 224 is a nice streetable cam. Good power, and a fair idle. One thing I have heard about the Hot Cam is that it's lobes are tighter from front to back. Meaning that some cams will have more cernterline variations, while it is pretty dead-on.
There is a reason why you don't see any of the popular cams with a 10 degree split pattern.
Another User it doesn't idle like stock for me. But it does make good mid-range power. I think my idle is set to 800 though. It has a beautiful sound to it and the car pulls hard.
People talk a lot of trash on the hotcam. I think it's an awesome thing. I have full intentions on going to a Bigger cam when I switch to turbo but if you're researching and taking your time to really thouroughly learn cams or what ever. It's a great cam to switch to and not know anything about cams.
You can sleep soundly knowing it's going to make good power, drive well, and not give you any problems.
IMHO it's an I want to upgrade my cam but don't know what to do cam. Yet still know you're gonna get good benefits all around with no disadvantages.
I'm completely happy with the cam. Kinda worried about upgrading now cause I'm so happy with it I don't wanna mess up and choose the wrong cam.
Thats my .02's and Blake rims look nice on your car seeing them makes me miss them
BTLFEDSS
