Knock retard
A good octane booster might be a safer choice. Ultimately, the higher octane like you suggested might help diagnose the problem. There might be a custom tune that is causing so much grief...(too much timing). Or there is excessive carbon buildup which could possibly be alleviated by some top engine cleaner.
did your friend put an aftermarket maf on the car? some of those have been known to do some messed up things.
I have a 408 iron block with JE pistons, Callies crank, Oliver rods, dual springs with comp lifters, hardened push rods, ect...yada yada. I have tried just about everything and I can't get rid of the KR!!!!
