What ring gap for this crazyness?
Old Jan 22, 2005 | 10:56 PM
GueSS Who's Avatar
Default What ring gap for this crazyness?
Iron 408
Lunati billet crank and rods
Diamond Nitrous Pistons (12cc dome with valve releifs and gas ports)
Hellfire rings
Solid roller cam (265/278 625/631 112)
CNCed heads (59cc chamber)
cometic head gasket (.074in thinkness) Should put it abit over 15:1 CR
400 worth of bottle on top of it. LOL
Lots of race gas
I have sent various people emails on this and wanting to know some other peoples thoughts on this. I will be doing the ring gap myself and was wondering what I need to set them at.
Old Jan 22, 2005 | 11:20 PM
Ben R's Avatar
Big. Haha.
That's a unique setup but if I had to answer I'd probably say about .024 on the top. Bigger probably wouldn't hurt you though. There are some variables here, however.There's a lot of debate about the second ring. .026 is probably the minimum gap for the second ring. Keep in mind that whatever gas gets past the top ring DEFINATELY needs to get past the second ring.
Consult your engine builder though.
Old Jan 22, 2005 | 11:46 PM
LOnSLO's Avatar
We have a similar setup. I used .026 on my top ring.
Old Jan 23, 2005 | 01:42 PM
GueSS Who's Avatar
and your second ring also?
Old Jan 23, 2005 | 03:02 PM
strokedls1's Avatar
I get 14.45-1 with a 4.100 bore gasket. The piston manufactuer gives you a multiplier to set the rings up for heavy nitrous or FI. Sounds like it will be a beast.
Old Jan 23, 2005 | 04:23 PM
Ben R's Avatar
Most people use .004" per inch of bore for an N/A application and .006" per inch of bore on a nitrous application.
On a BIG nitrous application we've gone all the way to .008" per inch of bore. That was on a serious nitrous motor that saw lots of freshens and a plethora of new parts per freshen. She ran good though.
Old Jan 23, 2005 | 04:24 PM
GueSS Who's Avatar
Yes I do have a ring sheet to tell me this, but I was just wondering if anyone had some different thoughts on this. I know alot of engine builders don't go by the ring specs in the box.......and yes it should be a beast. Shooting for 525+ on motor through a PG and a 9in on slicks.
Old Jan 23, 2005 | 04:29 PM
Ben R's Avatar
It's pretty much the standard. A lot of nitrous motors have special hone jobs to help with ring seal. And I see you've already got the good Hellfire rings. All that's left is choosing an engine builder that's experienced with big nitrous motors.
Old Jan 24, 2005 | 07:19 PM
GueSS Who's Avatar
I have built my motor and many other LS1's. I consider myself a good engine builder but there are some differences for a nitrous motor. That was why the ? about the gap. Every other thing is pretty standard to install.
Old Jan 24, 2005 | 08:47 PM
LOnSLO's Avatar
Well, for 4.030" bore, and all the nitrous it can inhale, I would stay under .028 or so. That should be plenty.
