How far can my heads be milled with a C2 cam?
I don't want to run into any Piston to Valve Clearance problems with a set of 5.7 Liter heads. So I'm wondering how far can the heads be milled so I don't run into PTV clearance trouble?
Thanks in advance
Floyd
Thanks in advance
Floyd
D(irecto)r Pepper
Re: How far can my heads be milled with a C2 cam?
I ran mine at .060 when i ran the MTI dual springs and MTI stage 2 heads and the C2 cam.
Good luck.
John
Good luck.
John
What is the spec's of the C2 cam? As i'm going though the same problem myself. I'll be getting my heads this week (SII 5.7 milled .30) along with my custom 228/235 .588.602 cam, and I'm worried about my P/V clearance as-well. Can someone shed light on this please. Also, do I stick with the stock length pushrods (7.4) or go with 7.35??????????????
So U used an MTI C2 cam with heads that were milled .060?
I have ls6 heads milled .055 and I am worried about piston/valve clearance issues...
Did you clay the pistons; use a thicker than stock head gasket? What clearance did the cam provide? What sized pushrods did you use?
Thanks...
Thanks...
