O-ringed heads: Gasket alignment
When placing the 6l graphite gasket on the head sealing surface, the o-ring is right under the fire ring of the gasket. At some points, it looks like the o-ring is even on the inside edge of the fire ring.
Maybe I am just confused about how o-rings work. I thought they were supposed to be just on the outside edge of the fire ring in the gasket? It looks as though the o-rings will cause the head to sit off the surface of the gasket.
Maybe I am just confused about how o-rings work. I thought they were supposed to be just on the outside edge of the fire ring in the gasket? It looks as though the o-rings will cause the head to sit off the surface of the gasket (see gap in picture)
__________________
