TRex cam owners inside...anyone probs???
Old Jan 31, 2005 | 11:23 AM
jrp's Avatar
jrp
SN95 Director
the Trex fits a specific application, if it meets yours then i say its a great cam. however alot of people would be better served by something else. sound is subjective, you can take a HC and drop the idle and make it lope like you've never heard.
Old Jan 31, 2005 | 01:35 PM
DanZ28's Avatar
You can DD it, but I don't consider it a DD IMO. I t took me some time to get the tuning just right, but it runs real good on the street, traffic, heat, doesn't stall, buck, etc. I don't DD mine, but I do drive it (when not working on it) to work a couple times a week when weather is good. I do rev mine to 7200 RPM at the track where it likes to run and I put down 430 WHP in my A4 with it.
Dan
Old Jan 31, 2005 | 01:46 PM
CWS6's Avatar
Originally Posted by Fireball
looks like you already have good gears for it, is your car a A4? If so you will want a higher stall.
M6
Old Jan 31, 2005 | 06:21 PM
WS666's Avatar
I daily drive mine and love it. I have put 20K on the car since the swap and the only thing I would change, is I would have had Jeremy Formato from Rev Xtreme tune it in the first place. With typical bolt ons and the cam, I put down 426 to the wheels, and I dont have any bucking, or other drivability issues.
Old Jan 31, 2005 | 06:33 PM
SMOKIN01TA's Avatar
Originally Posted by MachoCamacho
A quote I got from Smokin01TA, "My car was perfectly fine as a daily driver until i took out the AC/Heat"
yea i didnt like the sweating my butt off part.
i drove it daily for a few months, surges lil bit under 2000 and after that hold the xxxx on. im running 4.56 gears which helps a ton with traffic and so far has dynoed a best of 442 to the tires through the 12bolt. with some tuning adjustments and additonal intake work im hopin for close to 450rwhp and around 400rwtq
Old Jan 31, 2005 | 10:49 PM
kickassT/A's Avatar
mike has been telling me about you. you're car hauls man. guess chris's car is just a dud.
Old Jan 31, 2005 | 11:01 PM
SMOKIN01TA's Avatar
if so tell that fool to shoot me a pm with his new ph#
Old Feb 1, 2005 | 12:35 AM
02WHITEZ's Avatar
what valve springs are u guys running with this cam
Old Feb 1, 2005 | 01:01 AM
SMOKIN01TA's Avatar
crane duals with .030 shims
Old Feb 1, 2005 | 02:47 AM
chrdij's Avatar
The cam is all in the tune. I drive mine every day 2 school and work around the D.C. area! This cam pulls like a ****, and idles right at 950 rpm. I have to let it warm up for about 2-3 min and it will be surge free. Good luck with the setup!
Old Feb 1, 2005 | 06:17 AM
Fireball's Avatar
you also have 60 more cubes to swallow it up
Old Feb 1, 2005 | 06:40 AM
  #32
2MuchRiceMakesMeSick's Avatar
I street mine every day but im selling all the stuff on my car to buy a z06. Its not bad as long as you have a good tune. Gas mileage sucks but who cares about that right. If anyone wants this cam pm me and ill sell it
Old Feb 1, 2005 | 11:30 AM
  #33
WS666's Avatar
Like you said, all in the tune, i get 24mpg on the highway.
Old Feb 1, 2005 | 11:34 AM
  #34
02WHITEZ's Avatar
U HAVE TO SHIM IT WHY?
Old Feb 1, 2005 | 01:13 PM
  #35
DanZ28's Avatar
To get correct seat pressure. The older Cranes where supposed to be a .030" shim and the newer I think was around .060" shim. You should measure your install height and shim according to the recomended specs.
Dan
Old Feb 1, 2005 | 01:29 PM
  #36
93LS1RX7's Avatar
Actually the new Cranes are a .090" shim at least that is what Thunder told me and what I installed.
And yes you get the correct seat preesure.
Old Feb 1, 2005 | 03:20 PM
  #37
CWS6's Avatar
Well, the trex is on its way. What about injectors? will stock (02') work?
Old Feb 1, 2005 | 03:35 PM
  #38
02WHITEZ's Avatar
i don't like the idea of having to shim the springs doesn't seem very dd to me
Old Feb 1, 2005 | 03:54 PM
  #39
WS666's Avatar
I'm runnin with my stockers. My last dyno tune showed that I had almost maxxed them out though. So if you plan on any other decent mods, you will want to step it up a bit.
Old Feb 3, 2005 | 09:07 PM
  #40
CWS6's Avatar
the trex is here and going in the car tomorrow. I'll post up a vid when its running
