cam for 408 N/a??
Old Feb 1, 2005 | 03:20 PM
98sspullin'em's Avatar
Default cam for 408 N/a??
i did a search but didnt see any cam suggestions for a 408 n/a set-up??
what cam and spec's are ya'll running and with what heads??
and what ratio rockers would i need??
thanks, dwayne
Old Feb 1, 2005 | 08:30 PM
VINCE's Avatar
Shorty Director
Contact Futral Motorsports. They have a nice 408ci cam selection.
Old Feb 1, 2005 | 09:09 PM
BrentB@TEA's Avatar
I am using a 244/248 in mine with renegade lobes. I am loving it so far. I will post when I have some numbers for it.
Old Feb 2, 2005 | 02:39 AM
Sam 04 GTO's Avatar
I've got a Comp Cams 242/246 in mine, with a 114 LSA. Nice idle, not too choppy, and pulls great to 6,600.
With Patriot ST3 LS6 style heads, it makes over 400ft/lbs at the wheels from 3,000rpm and up.
Old Feb 7, 2005 | 08:35 PM
i was thinking about a 244- 248 on a 113, but didnt know if that was to big
and with what a 605-615?? thanks
Old Feb 7, 2005 | 08:52 PM
10secondZ's Avatar
I went 242*/250* .609"/.615" 114 LSA ..but I am hitting mine with a 300 DP...Should still make great power on motor though. but I would say a 242/244 .600"/.610" 112-114
Carter
Old Feb 7, 2005 | 08:55 PM
BrentB@TEA's Avatar
mine is .580 lift, It should be a little easier on the valve springs.
Old Feb 7, 2005 | 09:14 PM
tim99ws6's Avatar
I have a FMS 242/246 with a low LSA if you're interested.......it's over .600 on the lift
It is NIB, never taken out of the cover before. With the original FMS cam sheet and all!
Let me know if you want it!
tda2e@mtsu.edu
Old Feb 7, 2005 | 09:24 PM
ForceFed HP's Avatar
Suspended Sponsor Account
dwayne- that should work well and while I don't have my cam stuff in front of me that lift sounds about right or you could do something similar using the renegade lobes and keep the lift at.580
are you planning on spray?
brief thread hi jack
BrentB I sent you a PM
Old Feb 7, 2005 | 10:00 PM
Boostaholic's Avatar
I ran TREX in my N/A 408, worked great.
Old Feb 8, 2005 | 07:13 AM
DAPSUPRSLO's Avatar
Any solid roller guys. I was thinking in the mid 250/mid 260s for my 408 all motor. I'm sure I'll change my mind though.
Old Feb 8, 2005 | 08:12 AM
my 408 has a 250ish/260ish hyd. roller cam and some serious lift, just get good lifters.
Old Feb 8, 2005 | 02:17 PM
DAPSUPRSLO's Avatar
What kind of separation and icl? What are you spinning your motor to? Thanks.
Old Feb 8, 2005 | 02:55 PM
112LSA and icl of 106. planning to spin to 7200-7500rpms
Old Feb 8, 2005 | 03:39 PM
MeanWS6's Avatar
I went with Speed Inc's SS3
its a 242/250 .611/.619 114 it was cut for strokers and is what they use in all their big motors
Dynoed 458rwhp/532rwtq though a 12bolt and Th400
I could not have chose a better cam
Old Feb 8, 2005 | 05:02 PM
kumar75150's Avatar
I had a 244 250 .625 112lsa cam in my 408
I am going with a 253 261 .645 113lsa later this week
Old Feb 8, 2005 | 07:29 PM
383ss's Avatar
wasn't that cam designed for stock heads??
I'm running a 246/250 .632 fms cam. trapping 130+. I'm going to go bigger though, so if you are interested... less than 300 miles and 12 passes on it.
Old Feb 9, 2005 | 07:03 AM
DAPSUPRSLO's Avatar
I just noticed you said hydraulic roller. You planning on spinning it that high with hydraullic lifters. I don't think the Rs will take that, especially with any kind of agressive lobe. Also, I don't think you will find a spring for that that won't either collapse a lifter or float the valves. Maybe I'm wrong or maybe your running the rev kit.
Old Feb 9, 2005 | 08:19 AM
sorry I probably should have provided more details, my Dad (aka Demon SS) has spent many hours researching the motor setup in this car and talked to many cam pros and what we came up with is the cam I mentioned and we are using the Comp 921 springs and Schubeck lifters. the car is finally starting to come together after many changes, but we hope to find the power band more in the 6500-7000 rpm range but with a little cushion built in.
Old Feb 9, 2005 | 09:27 AM
DAPSUPRSLO's Avatar
Now that makes more sense. 7000rpm with hydraulics, especially like the R's, Schubeck, and Morels, is deffinately obtainable.
