Cam install $$$
lol. Just for comparison.. Peace,
Josh
There are some very good "shade tree" and "side job" installers out there for sure who help folks out. We have also seen the other side of jobs with a lot of issues to take care of before tuning. Be careful of who you choose to do the install as it may end up costing more in the end. Hope this helps.
Mike Norris
Joe
the only people that have to really worry about it are shops who have to work with the insane hypercritical customers and idiot employees.... (both happen at times, even to the best of shops)
Mike Norris
Mike,
My mistake was that I purchased the cam without researching or getting quotes for cam installs. I was merely going with the fact that from what I’ve personally seen, cam and valvespring swaps on LS1 engines or non-LS1 engines usually take 5 to 7 hours on people that have done this type of work before. So, I just took the fact that most speed shops usually charge $75 and hour which I figured it would run around $400 to $500 range. So that’s why I was amazed at the price.
I know you do a great job and your reputation speaks for itself, but I honestly can’t pay $700 for a cam swap at this point. But, I will see if a buddy that has done cam swaps before can help me out and we can do this project. If not, I will definately take it to you, but it definately won't be for a while since I can't pay that right now, and that's not including the price of the tune.
Regardless, I definately would like you to tune the car after the cam swap.
Thanks
I don't have a problem "turning wrenches". I have taken off the cylinder heads of an LS1 engine, and I'm sure that's a worst job to do then cam swap. But, since this is my daily driver and I really didn't want to spend a weekend working on my car I was really looking for somebody to do it for me?
And I also don't have all the tools to do this.
For what it is worth, most honest shops do not go by actual time to do a repair, but rather book time for a guide such as Motors, Chilton or even calculating GM warranty time by 1.4 to get a non warranty time. Valve spring book time by themselves is 5.7 hours. A cam swap runs in the 13.3 hour area, but that includes cylinder head R&R per the "proper" way to do the install. So lets say 50% of that time as cam swap or 6.6-6.7. That 6.6 plus the 5.7 for a total of 12.3 hours at $75 an hour, or $922.50. Our $695 comes in about 25% under that so I do not have a problem with us charging that much. When you have a 13,000SF shop, state of the art equipment, top technicians, insurance for them and the cars as well as all the little things a performance shop needs to run, there is going to be overhead for sure that needs to be paid. Those doing the home or side job installs have no overhead to worry about and therefore can be less expensive and actually do a good job. The problem arises when a lifter drops, timing set not aligned properly, leaks occur after the install and how that is handled that can make a huge difference. Just food for thought.
Can things be done for less? Definitely. Can they be done properly for less? Definitely. But when you need the car back in a short time and potential issues are not an option, these are things to think about. You also mentioned that you wanted to get the car here for just one day as in drop it off in the AM and pick her up in the PM installed and tuned. Can this be done? Definitely. But I prefer to heat cycle the springs at least twice and usually 3 times for a better chance at a good sping life. Just the way we do things here.
I have talked to other shops that will do this for $450-500 and asked them what happens if they drop a lifter, they say that that is the responsibilty of the owner of the vehicle to pay for the additional labor and parts for the retrieval and reinstall of the lifter. If we drop one at the $695 price, we take care of it.
Talk to you soon.
Mike Norris
Mike Norris
Are you covering yourself for a possible mistake???????????????????
Mike Norris
JMX's guide If I wanted to also swap out my timing chain and oil pump would that be extra labor cost?
try to do this yourself.theres only 2 tools that the average man doesnt have,valvespring compressor" MORE PERFORMANCE makes a nice one" and rods that go in the block to prevent lifter from falling"ls1 speed makes them".it should take a full day to do this the first time if you have all your parts/tools.
