which cam would u put i n ur 6 spd?
If you're on the street a lot, I'd look into something in the 230 range for duration. That way you won't give up to much tq down low. It will make street driving more fun and less of a headache also.
Originally Posted by madpwr1
this thread is
he only wants a BIG cam cause it's the new fad ... just put in a tr224 and call it a day
ive seen the tr224 run, its lopes waay too hard for the performance.
Originally Posted by nspr8td lt1
not everyone wants the "me too" cam
let me guess what cam you have ... most likely g5x3, g5x4, or trex ... you're right not everyone does want the "me too" cam
there are only about 5 cars on ls1tech with the g5x4. how many have the tr224? i know of at least 5 cars with that cam locally, it lopes harder than a mti t1 and makes less power. so why go with it?
i have a g5x4 for now, im getting a custom grind from my engine builder in about 6 months.
2)nice sounding idle
3)very very streetable
4)there is a reason that everyone has it, it's a good f'n cam!
cool guys yall have been really helpful and thanks alot for the last post jrp. ive been looking on ur cam guide. i think ive decided on the trex. so far ive calculated 3k and i dont even have the car. o well ill look thru the search what else i should get. beside the obvious. headerss, intake, and a cam kit from thunder.
is there guy on here that represents thunderracing? i know they are a sponsor so i was hoping iu could talk so someone. if anyone know please let me know. thanks a million.
#32
In addition to the Futral and others mentioned, take a look at the TSP cams, the 233/239 makes great torque (everyone I've seen and talked to loves that cam), the magic stick/MS3 makes some great numbers as well (again lots of fans on this one) and is in alot of street driven M6 cars. They also have their Giant cam which is just a massive bumpstick, also a 235/240 would be interesting but not alot of them are out there yet. All of these are streetable in an M6 car depending on rear gears and your personal driving habits/style. Personally I'm about to do the 233/239 for the tq curve since that is what moves the car, not the hp IMO.
Big cams can result in changing the springs out more often too, so they are not a drop in and forget about it mod at all to my knowledge. The rest of the valve train needs to be closely looked at too when going into anything over 220 from what I've learned.
#33
#34
#35
Originally Posted by NO5.0
WHATS UP WITH TH3E G5X4? Im going with the G5X3 and wanted to take one look before my decision. what about the T-rex?
#36
cause only a handful of people have had success with these BIG cams and a lot have had the same results as if they had a tr224, how many BIG cam 10 sec cam only cars are out there? ... most BIG cams run 11's and a tr224 will get you an 11 sec slip too ... maybe i missed the point of goin that big when it doesn't do anything
#37
If I planned on staying cam only forever, I'd probably have gone with a 224 or a 228 cam at most... since I'm sure I'll want some heads and an lsx intake at some point, I went with a cam that will match well with those mods in the future, but still do well for me today.
#38
Originally Posted by cyphur_traq
Dude you need to calm down. This is the second time I've been tempted to reply with a temper to your posts. Last time if you recall, it didn't go so well. Why must you be an instigator so often? If other people don't agree with you, so what. If you really have to voice your opinion so hotly about everything then call Oprah or Sally Jesse Raphael. Quite bitching on the forum please, its a waste of everyones time.
the guy wanted help in choosin a cam ... i thought he'd be better off with a cam that's more streetable and proven then just jumpin on the bigger is better bandwagon ... i got a response askin why would i recommend the cam i did when a bigger cam would give better results and i replied accordingly ... i could of chose my words more carefully, but i don't really care
so when you decide to get off my nuts let me know, in the mean time
#39
Originally Posted by Tranzor_Z28
If the platform is set up perfectly for each cam, the bigger cam will win... it's simple physics.
stevensls1 has chosen his cam, trex, and i wish you all the luck ... hope everything works out as planned
#40
i think you're the one that needs to calm down ... i ain't bitchin bout nothin ... you're bitchin bout my post
