What cam is this?
Old Feb 3, 2005 | 08:12 PM
RUF SS's Avatar
Default What cam is this?
Hi there guys,
I just got a 02 ZO6, I pulled the cam it had and it had an engraving on it that says
LS CHS 290 283 HR 112 512089
Anyone knows what cam is this? I mean what is the @50 numbers?
I pulled this cam because it idled like crap and sometime dies. Also, I used to get a SES light because of it (I am thinking a big cam) I did not have LS1Edit so tuning was a problem! Final solution was to just change it! I pulled it out and put a TR227 in there and all the of nightmare left! No more surging and all the other crap! Now, it just drives very well and it is very cool in traffic and yet pulls like hell!
Thanks!
Old Feb 3, 2005 | 10:23 PM
Cal's Avatar
Cal
That's a pretty big cam:
240/233 112 LSA @50 thou
Comp Cams custom grind?
Old Feb 4, 2005 | 05:39 AM
RUF SS's Avatar
Thanks for the reply,
I have no idea if it was comp or not. all what was engraved on it I have put it on my last post. But man, 240/233 that is something that I would put on a 383 stroker!
Old Feb 4, 2005 | 09:54 AM
Unaffliated Racing's Avatar
It's not a Comp grind. Cal where did you get those @.050" numbers?...did you just pull them out of a hat?lol
Old Feb 4, 2005 | 11:00 AM
Cal's Avatar
Cal
Yep! I calculated them by subtracting 50 degrees from the .050 numbers. Not 100% accurate, but usually close. Sorry, I should have said that.
Old Feb 4, 2005 | 11:13 AM
Lol...kind of shooting in the dark..huh?lol
Old Feb 4, 2005 | 11:22 AM
Cal's Avatar
Cal
Yes, but if he wants to know exact numbers, he could degree it with a dial indicator and lathe real easy.
Old Feb 5, 2005 | 03:37 AM
RUF SS's Avatar
Could you please tell on how to do it? I want to know what this cam is and how to check it! Thanks!!!
Old Feb 5, 2005 | 11:36 AM
NVR4GET's Avatar
What color is the Z06? Did it have headers? did you no it had a cam?
Matt
Old Feb 6, 2005 | 05:42 PM
Cal's Avatar
Cal
You also need a degree wheel, or some way of measuring shaft angle accurately. A lathe is just one way to solidly support the cam while you rotate it and take the measurements. Dial indicators are only $10 at Harbor Frieght. The lowest place on the cam is the base circle, the highest place it the lift. So zero the dial indicator on the base circle, take the highest reading and multiply by the rocker ratio (1.7) and you have the lift. Do that for one exhaust and one intake. The number of degrees you read off between 50 thou lift at the start of the lobe and 50 thou at the end is the duration.
Old Feb 6, 2005 | 06:00 PM
jmX's Avatar
jmX
Ruf, you got a vette huh...and now you have the same cam mine has!
If you think you can settle for knowing the lift only, you can go get a cheap dial caliper or digital caliper somewhere for $10-$20 and just find the smallest measurement on the lobe and subtract that from the biggest measurement on the lobe. Then mult by 1.7 and you'll get your valve lift number (like 0.600").
I'd guess it'd be specs close to a G5X3, simply because its a common cam...especially in texas it seems.
Old Feb 17, 2005 | 08:06 PM
RUF SS's Avatar
Thanks guys for your help!
NVR4GET, it is black ZO6, I got it from a used car dealer in Austin. it had no headers but had a cam. The car was very clean and in great shape. it picked up like crazy, but I did not like the cam for a daily driver!
jmx, how are you man? How is your car? Thanks for you info! I will try that. I got this cam in this engine for now! I am building a new stroker for the ZO6. Man, 477 rwhp from my SS with a 382 is not bad! Let us see what the LS2 block and AFR heads make!
