OK, cam swap & add ons advice...
For those with experience...
I have ordered the TR 224/224 .563 @ 114 LSA cam, with the TR cam pkg, 918's etc, rods, etc....
I have also ordered Katech LS6 ported oil pump & LS2 timing chain.
I do NOT desire to do a pulley or an electric water pump or heads at this time...
Is there anything else that is recommended??
(Car is full bolt ons)
Thanks....
Thanks....
You will need a pulley bolt; stock one is not reuseable. How about some titanium spring retainers? Or some aftermarket rockers? The stock rockers are known for slinging their needle bearings, even without the added load of aftermarket valve springs. You will need some kind of spring compression tool also. Any cam will work better with headers!
BTW, that's the same exact cam I just took out of my engine; are you sure you don't want something in the 230 range?
Dude.. I'm not doin the work....
My shop has or will get whats needed..
The titanium retainers are all part of the kit..
Stock rockers are fine....
Anyone else think of something I might or should be doing?
Originally Posted by rufretic
Why don't you want to do the pulley? No install charge if your doing it with the cam. If you decide to do it later it's going to cost you.
Have it dude..
Got ALL the bolt on stuff...
I was thinking more of the stuff related in the actual cam swap, stuff that wouldn't normally be easily accessed..
I guess other than the chain & oil pump, the only things are the pully & water pump which as I said earlier I'm not gonna do..
Thanks all for the posts..
Looks like I'm all set..
where did u get the pump and chain? katech? never heard of them are they a sponsor here thanks..
yea if u have a big stereo the pulley proll isn't the best idea.. ur prolly fine with what u got, goodluck!
Yep, got a pack of 5 O-rings...
Ordered the LS6 pump from Katech. Its just ported, NOT shimmed...
And yea, no pulley or electric water pump.
Can't wait for my shop to do the install.
Buick Grand National World Drag Race Champion, Dale Cherry, of Berrell Auto in Abington PA is doing the install, with dyno tuning by Bryan Herter of PCM for Less.
