which intake/injectors should I run
Old 02-06-2005, 10:02 PM
Wades SnS's Avatar
Default which intake/injectors should I run
I have a stock bore ls1 w/ a comp cam .601/.601 236/236 112+2 lsa and a set of 5.3l heads shaved .020 that flow near 305cfm on a 4" bore I am almost finished with fabbing everything for my s-10 so a 6.0l intake will work. I don't have any clearanced issues. Is the lsx intake worth the additional cost. Also will I need a bigger injector than the stock 00' LS1 injectors?
Thanks,
..RJ..
Old 02-06-2005, 10:07 PM
jrp
SN95 Director
jrp's Avatar
whats the application? and yes i'd get bigger injectors, 99-00 are only 26#.
Old 02-06-2005, 10:11 PM
destroyerSS's Avatar
do it right the first time LSX and 30 LB svo injectors will work fine
Old 02-06-2005, 10:14 PM
Wades SnS's Avatar
I'll drive it when its not raining or snowing and run who ever when ever if that is what you mean by application. I don't mean to sound cocky because Iam not by any means. I just enjoy racing I am not sayng that It will be untouchable I am just tired of the local mustang- import guys running there mouths and decided it was time to fix the problem
Should 6.0l injectors be enough or should I buy something bigger? I also forgot to add that I am running custom 1-3/4" long tubes and a ported TB
Old 02-06-2005, 10:20 PM
jrp
SN95 Director
jrp's Avatar
by application i mean use; strip, street, towing, ect. what are your h/c spec's?
Old 02-06-2005, 10:36 PM
Wades SnS's Avatar
Mainly street some strip no towing.
heads are
Lift Intake/Exhaust
.100 92/86
.200 164/114
.300 217/147
.400 255/182
.500 284/209
.600 307/226
cam is .601/.601 236/236 lsa 112 +2
I am unsure how close the cfm's are the guy that I had flow my heads his bench is older than me but gave me a good idea of what i have. Also I don't know if this is important or not but my runner volume hasn't been changed mainly trying to keep my velocity up. I am also running 2.02/1.60 valves. Ross standard replacement pistons. and a t-56
Thanks,
..RJ..
Old 02-08-2005, 12:40 PM
Wades SnS's Avatar
Are there any other suggestions? Is the LSX going to be worth the difference in price? How much of a difference should I see with the lsx over a 6.0l Intake?
Old 02-08-2005, 01:05 PM
Richiec77's Avatar
You might get by on 28.8lbs injectors but I would upgrade a bit more.
If you want 28.8 lbs injectors they are only $60 from Texas Speed & Performance with a new rail. If those aren't enough then you can upgrade and not be out much at all. Or you can even sell them on the parts for sale area to make most of your cash back.
Here's The link. They are a Sponsor.
http://www.texas-speed.com/9802fbody...tFld=9802fbody
Old 02-08-2005, 10:00 PM
Wades SnS's Avatar
Any takes or info on the 6.0 L intake?
