Drinking OIL!!
Where else can the oil be coming from?
The car does not puff smoke out of the dip stick or oil cap. Can it be the valve guides?
First, when the car is first started for the day (after sitting all night) look to see if it smokes alot- if yes, then it is the valve guides/seals. Do a compression leak down test to confirm your problem.
Bill
If it were the valve guides/seals it would smoke at idle.
NGK TR55
How many miles are on the motor? Does the oil get dirty/black fairly quick after an oil change?
