changing valve springs. any special tool ?
Old 02-13-2005, 04:16 PM
datsbad's Avatar
Default changing valve springs. any special tool ?
i am about the change the cam on my 99 motor . the engine is out of the car . is there a secial way to do this , or tool needed . thanks
Old 02-13-2005, 04:31 PM
freakynipples69's Avatar
yes. A valve spring compressor tool. Check the tools of the trade forum.
Old 02-13-2005, 06:07 PM
smask04C5's Avatar
If the engine is out of car and heads are coming off, a lever type valve spring compressor will work. if heads are not coming off, VHP valve spring compressor is a slick tool, iar up cyl and remove two springs at a time
Old 02-14-2005, 12:04 PM
LS1TECH Sponsor
Steve Burger's Avatar
The VHP/Crane tool is great for in car swaps.
Old 02-14-2005, 12:46 PM
v8maro's Avatar
I like the larry tool from tools of the trade section which was like $25. And I used it in-car with an air compressor holding the valves up
Old 02-14-2005, 04:45 PM
9 Second Club NA
Dragaholic's Avatar
My vote is for the Crane tool. I believe you can pick it up at Summit and Jeg's for $106. But there are several sponsors that sell them as well. I believe I got mine from Thunder Racing.
Old 02-14-2005, 05:42 PM
cyphur's Avatar
I picked up the Larry spring tool for 40 bucks. just got it in the mail last week, and it is a quality piece. Can't wait to put it to use. will prolly use TDC method to keep valves up.
Old 02-14-2005, 06:09 PM
GM Muscle's Avatar
Yep, if you can't get a Larry tool the VHP/Crane tool is the way to go. I also use the TDC method to hold the valves up. I just stick a straw in the plug hole to double check that the piston is all the way up.
