Bad lifter????
The noise isnt constant. 95% of the time its perfectly normal. But, everyonce in a while it will start to make a loud clicking noise that sounds alot like a bend pushrod. it will follow the rythem of the valve train the same as a bend puch rod as well. it onnly does it when the engine is up to temp. But then, like it wsa never there, it disapears..:dunno: it cant be a bent pushrod or valve, because it comes and goes.
i have it from a pretty good sourse that its probably a lifter. He says that the seat presure is very high on the new springs and cause isues with the old lifter s (almost 80K miles on them) maybe not oiling up correctly or getting air.
Based on what TSP told me, i just finished re-torqing the rockers to make sure it wasnt that, but its hard to tell if it was or not due to the fact that its so speratic.
What is your thoughts on this...is the DR chain a posible culprit?
pphilli1, did you figure out why your lifter turned? I had a defective lifter guide, but I still wonder if that's what really casued it.
dunno if the cam bearing was casuing my ticking, but i pulled my whole bottom end out.. better safe than sorry at 6500rpms lol
goodluck man
