Serious Engine Questions ... help w/ advice???
Could it be a bad PCV valve or is it what I think it is ... bad rings???? I don't believe the rings would be bad with only 36,800 miles on it. I have to add a quart of oil every 300 miles. Has anyone had this happen with such low mileage?
I would take it to the dealer before you do any head swap.You need to get this problem straighten out first.
It seems like this was when it started ... the massive oil loss and the black smoke. When I had it dyno-tuned (just after all the changes), on decleration, it backfired several times (while on the dyno) and shot 6 - 8" orange flames out the Borla tips ... a lot of black smoke, as well, just before deceleration ... then white smoke followed.
I chalked it up the raz or fuel light-off. I believe it's very possible it may be fuel related, but, not sure why that would make it consume or blow out that much oil ... about a quart every 300 miles.
old wisdom.
Black is soot, hydrocarbons, likely cause is misfires.
A modest over-rich condition just makes CO while
lean makes HC early on. Super-rich also elevates
HC but I don't get that impression here. You might
look for any signs that you have a single injector that
maybe doesn't pull its weight at the higher end. An
imbalanced set can give you an average AFT that's
right, but nobody's entirely happy. What's the ping
situation when this smoke show is going on?
It's odd that you are that lean down low (14.2) and rich
up top. Do you have numbers from your PE table and
your open loop fuel/air table? 14.2 is almost unenriched.
I wonder whether there's some weirdness about PE enable.
When I drove down the highway, I dawg'd it hard several times and not one trace of smoke ... black, gray, blue, or white!!!! Thanks for all your help guys.
Since it was all clogged up and smoking when I dyno'd, I'm curious if you think my dyno numbers might improve a little bit? I know that it feels stronger than ever before. I think I'll ask NLP to do a couple more dyno pulls for me.
I wound that thing tighter than a banjo srting and not a lick of smoke ... talkin' about one happy LS1 driver here ... hehehe!!!! It's nice that you folks would take the time to follow this thread through to try and help. You've definitely improved my knowledgeBase and given me a drive to learn more about our LS1 engines.
